1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: CA gateway with systemd
To: Ben Franksen <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 12 Jul 2017 11:13:00 -0400 (EDT)
I have a very similar setup to Florian and could probably help setup multi-instance (used it for other things).
Just a comment about systemd services in general.  I've been bitten by 'Requires=network.target'.  It doesn't mean NIS/YP is ready.  So I've changed things to 'Requires=ypbind.service', which comes after network.target.
Wesley
----- Original Message -----
> From: "Florian Feldbauer" <[email protected]>
> To: "EPICS Tech-Talk" <[email protected]>
> Sent: Wednesday, July 12, 2017 10:56:38 AM
> Forgot the "environment file" in the attachment...
> On 07/12/2017 04:54 PM, Florian Feldbauer wrote:
>> Hey Ben,
>> I setup the ca gateway using systemd. But I had only one gateway running
>> on the machine.
>> Maybe my scripts give you a good starting point!
>> Best regards,
>> Florian
>> On 07/12/2017 03:06 PM, Benjamin Franksen wrote:
>>> Hello
>>> Does anyone have an example of how to start the CA PV gateway using
>>> systemd? Is there a recommended best practice?
>>> Note: we want to run many gateways on the same machine.
>>> Cheers
>>> Ben
>| Dr. Florian Feldbauer                |
>| Ruhr-Universität Bochum              |
>| Experimentalphysik I AG              |
>| Universitätsstr 150                  |
>| D-44801 Bochum                       |
>| Office: NB 2/134                     |
>| Phone:  (+49)234 / 32-23563          |
CA gateway with systemd Benjamin Franksen
Re: CA gateway with systemd Florian Feldbauer
Prev: Re: help - writing a table column from OPI BOY to PV Kasemir, Kay
Next: Re: Autosave for waveform with 1 element Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: CA gateway with systemd Florian Feldbauer
Next: ioc crashing while using asyn & modbus Gary Croke
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
