Thx Mark
That works for integer arrays. Not sure why I was previously unsuccessful as I tried various combinations.
But the other waveform record holds an array of strings - field(FTVL,"STRING") – and continues to thwart me.
caput k1:osiris:ss1:posnames "one two three four"
caget k1:osiris:ss1:posnames
k1:osiris:ss1:posnames 4 one two three four
Trrying what I think is correct in SNL, I get compilation errors:
#define MAX_ENTRIES 100
string posnames[MAX_ENTRIES];
assign posnames to "{tel}{instr}:{mech}:posnames"; // this is the ‘string’ waveform record
local variable is:
string names[4] = { "0.100", "0.050", "0.035", "0,020” };
state STARTUP {
entry {
for (idx=0; idx<4; idx++ ) posnames[idx] = names[idx];
pvPut( posnames );
error: incompatible types when assigning to type string from type char *
Thx,
Al
You need to change it to:
#define MAX_LOCATIONS 1000
int locations[MAX_LOCATIONS];
assign locations to "{tel}{instr}:{mech}:locations"; // where locations is a waveform record with an integer array.
Do you mean a waveform record of type CHAR that is used to hold a long string? I think you just declare it as
char waveform[MAX_SIZE];
Hi
I cannot find an explicit example in regards to accessing the element values in a waveform array from within an SNL sequencer.
Does anybody have experience doing so?
Can’t seem to do this:
int locations;
int locs[4] = {0,300,600,900};
pvGet( locations );
locs = locations; // is the declaration for locations (above) correct?
error: incompatible types when assigning to type int[4] from type int *
locs = locations;
This fails too:
locs[0] = locations[0];
I guess I’m ignorant in regards to accessing the array values in the record.
Also, is it necessary to escape to C in order to update the elements in a waveform string record?
Thanks for any advice you have
Al
