1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: waveform arrays within SNL
To: 'Al Honey' <[email protected]>, "'[email protected]'" <[email protected]>
Date: Tue, 20 Jun 2017 19:28:09 +0000
You need to change it to:
#define MAX_LOCATIONS 1000
int locations[MAX_LOCATIONS];
assign locations to "{tel}{instr}:{mech}:locations";  // where locations is a waveform record with an integer array.
Do you mean a waveform record of type CHAR that is used to hold a long string?  I think you just declare it as
char waveform[MAX_SIZE];
From: [email protected] [mailto:[email protected]] On Behalf Of Al Honey
Sent: Tuesday, June 20, 2017 2:22 PM
To: '[email protected]'
Subject: waveform arrays within SNL
Hi
I cannot find an explicit example in regards to accessing the element values in a waveform array from within an SNL sequencer.
Does anybody have experience doing so?
Can’t seem to do this:
int locations;
int locs[4] = {0,300,600,900};
        pvGet( locations );
        locs = locations;               // is the declaration for locations (above) correct?
error: incompatible types when assigning to type int[4] from type int *
         locs = locations;
This fails too:
         locs[0] = locations[0];
I guess I’m ignorant in regards to accessing the array values in the record.
Also, is it necessary to escape to C in order to update the elements in a waveform string record?
Thanks for any advice you have
Al
RE: waveform arrays within SNL Al Honey
Prev: waveform arrays within SNL Al Honey
Next: Re: waveform arrays within SNL Southern, Tim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: RE: waveform arrays within SNL Al Honey
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
