Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: saving samples
To: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Tue, 13 Jun 2017 19:50:17 +0200
One of the functionalities of the compress record is acting as a ring buffer (for scalar values).
For arrays it can do averages. Either average over time, i.e. multiple array samples - like a scope - or average over multiple elements. If you combine two compress records after e.g. a temperature that gets updated every second, you can - in the first step - have a 3600 element time buffer over the last hour, then - in the second step - do a 60:1 average and have a 60 element buffer of the temperature averages of the last 60 minutes.
Cheers,
~Ralph
On Tue, Jun 13, 2017 at 6:06 PM, Miguel Bordalo <miguel.b.fernandes@gmail.com> wrote:
save in another PV the last sample (scalar) (or more samples) of other PV that is updated periodically.
this is for example: i have the temperature of a room being updated periodically. I want another PV to act as a buffer that stores the last two samples of the room's temperature . And i want to be able to acess them individually of course.
Thanks!
Miguel Bordalo
Licenciado em Engenharia Electrotécnica e de Computadores
Instituto Superior Técnico
On 13 June 2017 at 16:01, Ralph Lange <ralph.lange@gmx.de> wrote:
Please clarify a bit further.
What do you mean by "save"?
Write to a file? Store in an archiver? Write to another record?
What kind of PV?
Scalar or array data?
If array: does "last" mean last array in time, or last element in array?
Cheers,
~Ralph
On Tue, Jun 13, 2017 at 4:18 PM, Miguel <miguel.b.fernandes@gmail.com> wrote:
What is the easiest way to save periodicaly the last sample (or last 2/3 samples) of a certain PV ?
ty
saving samples Miguel
Re: saving samples Ralph Lange
Re: saving samples Miguel Bordalo
Prev: Re: saving samples Miguel Bordalo
Next: Re: How to add userTag to struct timeStamp in NTScalarArray Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: saving samples Andrew Johnson
Next: How to add userTag to struct timeStamp in NTScalarArray Heinz Junkes
ANJ, 13 Jun 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
