in your solution with calc. it is suppose that the INPA is the same as INPB ? So that as u wrtore it enables you to store the last 2 samples of a given pv, is that correct? also can you explain me the CP meaning in : field(INPA, "input CP") also what do you sugegst if i only need to save the last sample? If the pv i want to stores samples from is actually a calc by it selft i could even store the last sample in itselft as the way you showed. right? Ty ------------------------------------------------------------------------- Miguel Bordalo Licenciado em Engenharia Electrotécnica e de Computadores Instituto Superior Técnico [email protected] On 13 June 2017 at 17:49, Andrew Johnson <[email protected]> wrote: The compress record type that comes with Base can save a buffer of old
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
