1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: NFS mount problem from Ubuntu 12.04
Date: Sat, 10 Jun 2017 18:11:59 +0200
> bruker@photontest-1:~$ sudo apt-get install nfs-common portmap
> Any idea if the problem is indeed those missing packages,
If you don't have '/sbin/mount.nfs' (from nfs-common) then yes.
> and if so how to install them?
FYI, "portmap" has been replaced by "rpcbind", though this should be
resolved automatically.
If these are missing then likely a problem with the apt repository
config.  Most likely is that somehow the ubuntu.com repo lines have been
removed/commented out.
First see if any errors are shown by:
> apt-get update
On 06/10/2017 04:24 PM, Mark Rivers wrote:
> Folks,
> This is off-topic from epics but I am hoping someone can help.  I have
> an Ubuntu 12.04 machine (brukertest-1) from which I need to mount a
> Centos 7 NFS server (corvette).
> The Ubuntu machine is running this kernel
> bruker@photontest-1:~$ uname -a
> Linux photontest-1 3.11.0-15-generic #25~precise1-Ubuntu SMP Thu Jan 30
> 17:42:40 UTC 2014 i686 i686 i386 GNU/Linux
> I need to be able to mount the corvette /usr/local and /home from this
> machine.
> I have added this machine to corvette:/etc/exports and run exportfs –a.
> However, when I try to mount corvette I get the following error:
> bruker@photontest-1:~$ sudo mount -t nfs corvette:/usr/local
> /corvette/usr/local
> mount: wrong fs type, bad option, bad superblock on corvette:/usr/local,
>        missing codepage or helper program, or other error
>        (for several filesystems (e.g. nfs, cifs) you might
>        need a /sbin/mount.<type> helper program)
>        In some cases useful info is found in syslog - try
>        dmesg | tail  or so
> When I run dmesg on photontest-1 I see the following:
> [4283236.931503] RPC: Registered named UNIX socket transport module.
> [4283236.931506] RPC: Registered udp transport module.
> [4283236.931507] RPC: Registered tcp transport module.
> [4283236.931508] RPC: Registered tcp NFSv4.1 backchannel transport module.
> [4283236.943157] FS-Cache: Loaded
> [4283236.952960] FS-Cache: Netfs 'nfs' registered for caching
> When I look at syslog on photontest-1 I see the following:
> bruker@photontest-1:~$ sudo tail -1000l /var/log/syslog
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931503] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931506] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931507] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931508] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.943157] FS-Cache: Loaded
> Jun 10 08:43:55 photontest-1 kernel: [4283236.952960] FS-Cache: Netfs
> I found some documentation on setting up NFS in Ubuntu 12.04 here:
> https://www.digitalocean.com/community/tutorials/how-to-set-up-an-nfs-mount-on-ubuntu-12-04
> It says that I need to install the nfs-common and portmap packages.
> However, when I try to do that I get the following errors:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Package portmap is not available, but is referred to by another package.
> This may mean that the package is missing, has been obsoleted, or
> is only available from another source
> Package nfs-common is not available, but is referred to by another package.
> E: Package 'nfs-common' has no installation candidate
> E: Package 'portmap' has no installation candidate
> Any idea if the problem is indeed those missing packages, and if so how
> to install them?
> Thanks,
> Mark
NFS mount problem from Ubuntu 12.04 Mark Rivers
Prev: NFS mount problem from Ubuntu 12.04 Mark Rivers
Next: Re: NFS mount problem from Ubuntu 12.04 Jani Hakala
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
