1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: NFS mount problem from Ubuntu 12.04
Date: Sat, 10 Jun 2017 19:14:34 +0300
Mark Rivers <[email protected]> writes:
Does /etc/apt/sources.list have
     deb http://archive.ubuntu.com/ubuntu precise main
line? Also, if 'apt-get update' complains about not being able to fetch
something, that may be the reason why 'apt-get install' fails.
nfs-common and portmap are probably the right package names
(https://packages.ubuntu.com/precise/allpackages)
Jani Hakala
> It says that I need to install the nfs-common and portmap
> packages. However, when I try to do that I get the following errors:
> bruker@photontest-1:~$ sudo apt-get install nfs-common portmap
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Package portmap is not available, but is referred to by another package.
> This may mean that the package is missing, has been obsoleted, or
> is only available from another source
> Package nfs-common is not available, but is referred to by another package.
> E: Package 'nfs-common' has no installation candidate
> E: Package 'portmap' has no installation candidate
> Any idea if the problem is indeed those missing packages, and if so
> how to install them?
RE: NFS mount problem from Ubuntu 12.04 Mark Rivers
Prev: Re: NFS mount problem from Ubuntu 12.04 Michael Davidsaver
Next: RE: NFS mount problem from Ubuntu 12.04 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
