1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: string fanout or stringout after conditional check?
To: "Zimoch Dirk (PSI)" <[email protected]>
Cc: Eric Norum <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 May 2017 16:31:58 +0200
  For the closing purpose, I would like to reply this list.
I found the way to do what I need with aSub record. And I've learned other things than what I need as usual.
  Anyway, always thank you.
  Han
On 05/18/2017 11:39 PM, Zimoch Dirk (PSI) wrote:
The guard is not strictly necessary. StreamDevice will not overrun the buffer.
In recent versions I have improved string scanning: for example "%#s" reads strings containing white space.
But maybe you want to do more parsing:
in "user,%d,%(\$1)s";
This in an I/O Intr scanned record fetches the number whenever a line starting with "user," is received and sends the last part to a different record.
Dirk
Gruss
Dirk
Am 18.05.2017 um 17:22 schrieb Jeong Han Lee <[email protected]>:
Hi Eric,
On 05/18/2017 05:08 PM, Eric Norum wrote:
To guard against buffer overrun issues it’s best to specify a maximum
length in the protocol entry:
read_raw
  in “%39c";
 Thanks for your comments.
Or, if the input terminator is set to a single ‘\r’ or ‘\n’ and the
device sends a "\r\n” you could use:
read_raw
  in “%39[^\r\n]";
 By the way, I have the terminator in "st.cmd" as follows:
 asynOctetSetInputEos("L0", 0, "\r\n")
 Han
On May 18, 2017, at 6:37 AM, Jeong Han Lee <[email protected]
<mailto:[email protected]>> wrote:
I have the bar code scanner, so, the string input is the arbitrary
ascii and numbers from bar codes, generated by myself, whenever I scan
it.
For example,
case 1 : user,123456789,U002C007
case 2 : ABCDEFGHIZ0123456789
case 3 : office,248795493,M01B21
case 4 : ....
case N : SUBMIT
Note that case 1..N-1 can be done without order.
The scanner has a typical RS232 connection. I wrote the very simple
IOC with asyn and Stream. It has only one record and one function in
db and proto file as follows:
--- snip snip ---
record(stringin, "$(SYSDEV)RawScanData")
  field(DESC, "RAW Scanned data")
  field(DTYP, "stream")
  field( INP, "@scanner.proto read_raw $(PORT)")
  field(SCAN, "I/O Intr")
  field(PINI, "YES")
read_raw
  in "%s";
--- snip snip ----------
Is this enough?
 Han
Eric Norum
[email protected] <mailto:[email protected]>
string fanout or stringout after conditional check? Jeong Han Lee
Re: string fanout or stringout after conditional check? Ralph Lange
Re: string fanout or stringout after conditional check? Jeong Han Lee
Re: string fanout or stringout after conditional check? Eric Norum
Re: string fanout or stringout after conditional check? Zimoch Dirk (PSI)
Prev: RE: Force TCP/IP reconnect from Asyn/Streamdevice Mark Rivers
Next: support for Thorlabs ODC001 D Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: string fanout or stringout after conditional check? Eric Norum
Next: EDM questions lzf neu
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
