1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: string fanout or stringout after conditional check?
To: Jeong Han Lee <[email protected]>
Cc: [email protected]
Date: Thu, 18 May 2017 08:08:45 -0700
To guard against buffer overrun issues it’s best to specify a maximum length in the protocol entry:
read_raw
   in “%39c";
Or, if the input terminator is set to a single ‘\r’ or ‘\n’ and the device sends a "\r\n” you could use:
read_raw
   in “%39[^\r\n]";
On May 18, 2017, at 6:37 AM, Jeong Han Lee <[email protected]> wrote:
 I have the bar code scanner, so, the string input is the arbitrary ascii and numbers from bar codes, generated by myself, whenever I scan  it.
 For example,
 case 1 : user,123456789,U002C007
 case 2 : ABCDEFGHIZ0123456789
 case 3 : office,248795493,M01B21
 case 4 : ....
 case N : SUBMIT
 Note that case 1..N-1 can be done without order.
 The scanner has a typical RS232 connection. I wrote the very simple IOC with asyn and Stream. It has only one record and one function in db and proto file as follows:
--- snip snip ---
record(stringin, "$(SYSDEV)RawScanData")
   field(DESC, "RAW Scanned data")
   field(DTYP, "stream")
   field( INP, "@scanner.proto read_raw $(PORT)")
   field(SCAN, "I/O Intr")
   field(PINI, "YES")
read_raw
   in "%s";
--- snip snip ----------
 Is this enough?
  Han
Eric Norum
[email protected]
Re: string fanout or stringout after conditional check? Jeong Han Lee
Re: string fanout or stringout after conditional check? Ralph Lange
Prev: EDM questions lzf neu
Next: Re: string fanout or stringout after conditional check? Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: string fanout or stringout after conditional check? Jeong Han Lee
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
