1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: caRepeater: Syntax error: ")" unexpected
To: <[email protected]>
Date: Wed, 17 May 2017 10:02:38 -0500
I've recently built base 3.15.3 and 3.15.5 on the RPi (Pixel, raspbian jessie) defining only EPICS_HOST_ARCH. No additional installs were needed IIRC.
you might examine:
file caput
to verify it has the correct architecture.
Pete
On 05/17/2017 09:47 AM, nb wrote:
On 17.05.2017 17:37, Wang Xiaoqiang wrote:
How about using the binary
/home/pi/epics/base-3.15.5/bin/linux-arm/caget, instead of the perl
script version?
~/epics/base-3.15.5/bin/linux-arm $ ./caget
-bash: ./caget: cannot execute binary file
Okay, this seems like I built wrong binaries.
Instead of cross-compiling, you can compile epics base on RPi as well.
I tried that, but for some odd reason `make` entered some weird loop
compiling same files over and over.
I've checked versions of all the build-env stuff and it seemed ok.
I guess I'll just have to figure out why building on Pi doesn't work
properly then.
Kind regards,
Nick.
caRepeater: Syntax error: ")" unexpected nb
Re: caRepeater: Syntax error: ")" unexpected nb
Prev: Re: caRepeater: Syntax error: ")" unexpected nb
Next: Re: caRepeater: Syntax error: ")" unexpected nb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
