1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: caRepeater: Syntax error: ")" unexpected
To: Wang Xiaoqiang <[email protected]>, [email protected]
Date: Wed, 17 May 2017 18:14:25 +0300
On 17.05.2017 17:37, Wang Xiaoqiang wrote:
Instead of cross-compiling, you can compile epics base on RPi as well.
I ran make again and it compiled successfully in couple minutes. The only thing that changed in the system is that I installed libreadline-dev and swig (those were required to build pcaspy).
Is any of those required for the EPICS base? I didn't see it in the dependencies.
Kind regards,
Nick
Re: caRepeater: Syntax error: ")" unexpected Wang Xiaoqiang (PSI)
Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
Re: caRepeater: Syntax error: ")" unexpected Andrew Johnson
caRepeater: Syntax error: ")" unexpected nb
Prev: Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
Next: Re: caRepeater: Syntax error: ")" unexpected Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
