1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: AreaDetector bindings and RBV propagation
To: Iain Marcuson <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 10 May 2017 13:19:27 +0000
> I found that when I toggled the passed to ADStatus (alternating from 3 to 4 and back), the caget read the new value.
> It looks like it only updates on change.
Yes, that is true.  callParamCallbacks() only does the callbacks to device support if the value set by setXXXParam has changed since the last time callParamCallbacks() was called.  As you observed the only way to force a callback at present is to write a dummy value and then the desired value before calling callParamCallbacks().
Sent: Wednesday, May 10, 2017 8:11 AM
To: Mark Rivers; [email protected] >> EPICS Tech Talk
Thank you for your response, and sorry for not getting back to you sooner.
> >10. Caget $(P)$(R)DetectorState_RBV.  It is "Readout" (numeric value 2),
> not 3 as would be expected from step 9.
> That does not make sense to me.  If your driver called
> setIntegerParam(ADStatus, 3) and then callParamCallbacks(addr) then the
> record should have the value 3, not 2.
I found that when I toggled the passed to ADStatus (alternating from 3 to 4 and back), the caget read the new value.  It looks like it only updates on change.
Iain.
> -----Original Message-----
> From: [email protected] [
> The Get Status code is
> if (function == detector_get_status_)
>       printf("Received SDGetStaus command.\n");
>       // XXX Does putting a Get make the set take effect?
>       getIntegerParam(ADStatus, &det_status);
>       printf("Detector status before set is %i.\n", det_status);
>       setIntegerParam(ADStatus, 3);
> And the GetStatus record is:
> record(longout, $(P)$(R)GetStatus)
>       field(DTYP, "asynInt32")
>       field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))SDGETSTATUS")
AreaDetector bindings and RBV propagation Iain Marcuson
RE: AreaDetector bindings and RBV propagation Mark Rivers
RE: AreaDetector bindings and RBV propagation Iain Marcuson
Prev: RE: AreaDetector bindings and RBV propagation Iain Marcuson
Next: Re: Switched PDUs with EPICS support Tomaž Šuštar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: CSS PyDev - capturing mouse event Mogamad-Amien Crombie
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
