Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: AreaDetector bindings and RBV propagation
To: "'Iain Marcuson'" <Iain.Marcuson@sydorinstruments.com>, <tech-talk@aps.anl.gov>
Date: Mon, 8 May 2017 15:50:54 -0500
You might be missing the
callParamCallbacks();
any time that you perform a set command.
-----Original Message-----
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov]
On Behalf Of Iain Marcuson
Sent: Monday, May 08, 2017 3:29 PM
To: tech-talk@aps.anl.gov >> EPICS Tech Talk <tech-talk@aps.anl.gov>
Subject: AreaDetector bindings and RBV propagation
I have completed a basic AreaDetector module for my camera and am working on
adding enhancements.  Presently, I am attempting to add readback of
acquisition status.  I am unfamiliar with the normal operations of the RBV
PVs, but tried manipulating one for practice.  The sequence of events is:
1. Start IOC.
2. Caget $(P)$(R)DetectorState_RBV.  It is idle.
3. Run acquisition command.
4. Caget $(P)$(R)DetectorState_RBV.  It is idle.
5. Caput $(P)$(R)GetStatus  1.  PV and function are detailed below.
Initially reported value is 0, as expected.
6. Caget $(P)$(R)DetectorState_RBV.  It is "Correct" (numeric value 3, as
expected from GetStatus code).
7. Caput $(P)$(R)DetectorState_RBV 2.
8. Caget $(P)$(R)DetectorState_RBV.  It is "Readout" (as expected from
ADBase.template, numeric value 2).
9. Caput $(P)$(R)GetStatus 1.  Initially reported value is 3, not 2 as would
be expected from step 8.
10. Caget $(P)$(R)DetectorState_RBV.  It is "Readout" (numeric value 2), not
3 as would be expected from step 9.
The Get Status code is
if (function == detector_get_status_)
      printf("Received SDGetStaus command.\n");
      // XXX Does putting a Get make the set take effect?
      getIntegerParam(ADStatus, &det_status);
      printf("Detector status before set is %i.\n", det_status);
      setIntegerParam(ADStatus, 3);
And the GetStatus record is:
record(longout, $(P)$(R)GetStatus)
	field(DTYP, "asynInt32")
	field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))SDGETSTATUS")
Why are the values not propagating between parameter library and PVs, and
how does one update these readback value PVs?
Thank you,
Iain Marcuson.
RE: AreaDetector bindings and RBV propagation Iain Marcuson
Prev: AreaDetector bindings and RBV propagation Iain Marcuson
Next: RE: AreaDetector bindings and RBV propagation Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 08 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
