1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: AreaDetector bindings and RBV propagation
To: "Mark S. Engbretson" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 8 May 2017 20:53:12 +0000
I checked and I do have a callParamCallbacks(addr) call at the end of the function.
Iain.
> -----Original Message-----
> From: Mark S. Engbretson [mailto:[email protected]]
> Sent: Monday, May 08, 2017 4:51 PM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected]
> You might be missing the
> callParamCallbacks();
> any time that you perform a set command.
> From: [email protected] [mailto:tech-talk-
> [email protected]]
> On Behalf Of Iain Marcuson
> Sent: Monday, May 08, 2017 3:29 PM
> To: [email protected] >> EPICS Tech Talk <[email protected]>
> Subject: AreaDetector bindings and RBV propagation
> I have completed a basic AreaDetector module for my camera and am
> working on adding enhancements.  Presently, I am attempting to add
> readback of acquisition status.  I am unfamiliar with the normal operations of
> the RBV PVs, but tried manipulating one for practice.  The sequence of
> events is:
> 1. Start IOC.
> 2. Caget $(P)$(R)DetectorState_RBV.  It is idle.
> 3. Run acquisition command.
> 4. Caget $(P)$(R)DetectorState_RBV.  It is idle.
> 5. Caput $(P)$(R)GetStatus  1.  PV and function are detailed below.
> Initially reported value is 0, as expected.
> 6. Caget $(P)$(R)DetectorState_RBV.  It is "Correct" (numeric value 3, as
> expected from GetStatus code).
> 7. Caput $(P)$(R)DetectorState_RBV 2.
> 8. Caget $(P)$(R)DetectorState_RBV.  It is "Readout" (as expected from
> ADBase.template, numeric value 2).
> 9. Caput $(P)$(R)GetStatus 1.  Initially reported value is 3, not 2 as would be
> expected from step 8.
> 10. Caget $(P)$(R)DetectorState_RBV.  It is "Readout" (numeric value 2), not
> 3 as would be expected from step 9.
> The Get Status code is
> if (function == detector_get_status_)
>       printf("Received SDGetStaus command.\n");
>       // XXX Does putting a Get make the set take effect?
>       getIntegerParam(ADStatus, &det_status);
>       printf("Detector status before set is %i.\n", det_status);
>       setIntegerParam(ADStatus, 3);
> And the GetStatus record is:
> record(longout, $(P)$(R)GetStatus)
> 	field(DTYP, "asynInt32")
> 	field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))SDGETSTATUS")
> Why are the values not propagating between parameter library and PVs, and
> how does one update these readback value PVs?
> Thank you,
> Iain Marcuson.
AreaDetector bindings and RBV propagation Iain Marcuson
RE: AreaDetector bindings and RBV propagation Mark S. Engbretson
Prev: RE: AreaDetector bindings and RBV propagation Mark S. Engbretson
Next: RE: AreaDetector bindings and RBV propagation Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
