1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: CA gatway runs away when zero length PV name in UDP search request
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Apr 2017 16:45:50 +0000
Hello:
> From: Shuei YAMADA <[email protected]>
> CAS:
> Apr 20 06:29:30 !!! Errlog message received (message is above)
> zero length PV name in UDP search request?
> The machine in the logfile, jkjnuc31.ccr.jkcont (we're using private
> network for accelerator control),  is one of our PCs running
> CS-Studio
At the SNS we have also seen this zero-length PV name message in the CA gateway log.
I've updated the vtype.pv layer in CSS to catch empty PV names.
Then I found that the EPICS PV Tree tool would indeed request empty PV names when you enter such an empty name, so that's now also been fixed.
There might be more tools in CSS that ended up requesting empty PVs, and since that was so far just passed on, we didn't notice.
See  https://github.com/ControlSystemStudio/cs-studio/issues/2199 for updates.
Kay
CA gatway runs away when zero length PV name in UDP search request Shuei YAMADA
Prev: RE: Area Detector base class parameters Mark Rivers
Next: Re: CA gatway runs away when zero length PV name in UDP search request Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: CA gatway runs away when zero length PV name in UDP search request Shuei YAMADA
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
