If your detector supports binning then you need to handle ADBinX in your derived class writeInt32() method.
Here is an example from ADProsilica:
/** Called when asyn clients call pasynInt32->write().
* This function performs actions for some parameters, including ADAcquire, ADBinX, etc.
* For all parameters it sets the value in the parameter library and calls any registered callbacks..
* \param[in] pasynUser pasynUser structure that encodes the reason and address.
* \param[in] value Value to write. */
asynStatus prosilica::writeInt32(asynUser *pasynUser, epicsInt32 value)
int function = pasynUser->reason;
int status = asynSuccess;
tPvUint32 syncs;
static const char *functionName = "writeInt32";
/* Set the parameter and readback in the parameter library. This may be overwritten when we read back the
* status at the end, but that's OK */
status |= setIntegerParam(function, value);
if ((function == ADBinX) ||
(function == ADBinY) ||
(function == ADMinX) ||
(function == ADSizeX) ||
(function == ADMinY) ||
(function == ADSizeY)) {
/* These commands change the chip readout geometry. We need to cache them and apply them in the
* correct order */
status |= setGeometry();
From: [email protected] [[email protected]] on behalf of Iain Marcuson [[email protected]]
Sent: Thursday, April 27, 2017 10:25 AM
To: [email protected] >> EPICS Tech Talk
Subject: Area Detector base class parameters
I have been reviewing the Area Detector code and examining the interface between C and EPICS. I am not clear on how parameters from the base class are sent to the detector. For example, the parameter ADBinX is handled by ADDriver::writeInt32(), but nothing in that function actually outputs the new value to the device. Where is the transmission occurring?
Thank you,
Iain Marcuson.
- Area Detector base class parameters Iain Marcuson
Re: CA gatway runs away when zero length PV name in UDP search request Kasemir, Kay
<2017>
CSS perspective from OPI [email protected]
<2017>
