Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: Question about string operation in epics db ?
From: Iain Marcuson <Iain.Marcuson@sydorinstruments.com>
To: lzf neu <lzfneu@live.com>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 17 Apr 2017 13:20:19 +0000
Have you tried using a Rule to change the foreground color?  I can change the foreground to something other than its default using a rule, but I cannot figure out the semantics of specifying a specific value to change on.
Iain.
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of lzf neu
Sent: Monday, April 17, 2017 9:16 AM
To: tech-talk@aps.anl.gov
Subject: Question about string operation in epics db ?
I have a question to consult you.
PV name: "Global-second2_dword" is used to display 60 seconds countdown from PLC.
If the seconds countdown is less than 10, it displays a single digital in terminal. Now I want to add zero in the left of the single digital. eg.09,08,07,06,05,04,03,02,01,00.
Maybe string operation may solve the problem. I have tried  "scalcout" record, but epics displays the error message:
Record XXX is of unknown type "scalcout" and I have no idea how to write the db.
I have post the record in the following lines:
record(ai, "Global-Second")
    field(DTYP, "s7nodave")
    field(INP, "@s7_300 (PG=.2s) MW60")
    field(SCAN, "I/O Intr")
    field(FLNK, "Global-Second2_dword")
record(calc, "Global-Second2_dword")
        field(INPA, "Global-Second.VAL")
        field(CALC, "A/10")
Any help will be apprecieated and thanks in advance!
Zhefu
答复: Question about string operation in epics db ? lzf neu
Prev: Question about string operation in epics db ? lzf neu
Next: 答复: Question about string operation in epics db ? lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 17 Apr 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
