1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: 答复: Question about string operation in epics db ?
To: Iain Marcuson <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 17 Apr 2017 13:44:28 +0000
Thanks, it's a good idea. howeve, I want to change the PV value in db record, then display the PV in CSS rather than make the operation  in CSS. Any other idea? Thanks.
发件人: Iain Marcuson <[email protected]>
发送时间: 2017年4月17日 13:20
收件人: lzf neu; [email protected]
主题: RE: Question about string operation in epics db ?
Have you tried using a Rule to change the foreground color?  I can change the foreground to something other than its default using a rule, but I cannot figure out the semantics of specifying a specific value to change on.
Iain.
From: [email protected] [mailto:[email protected]] On Behalf Of lzf neu
Sent: Monday, April 17, 2017 9:16 AM
To: [email protected]
Subject: Question about string operation in epics db ?
I have a question to consult you.
PV name: "Global-second2_dword" is used to display 60 seconds countdown from PLC.
If the seconds countdown is less than 10, it displays a single digital in terminal. Now I want to add zero in the left of the single digital. eg.09,08,07,06,05,04,03,02,01,00.
Maybe string operation may solve the problem. I have tried  "scalcout" record, but epics displays the error message:
Record XXX is of unknown type "scalcout" and I have no idea how to write the db.
I have post the record in the following lines:
record(ai, "Global-Second")
    field(DTYP, "s7nodave")
    field(INP, "@s7_300 (PG=.2s) MW60")
    field(SCAN, "I/O Intr")
    field(FLNK, "Global-Second2_dword")
record(calc, "Global-Second2_dword")
        field(INPA, "Global-Second.VAL")
        field(CALC, "A/10")
Any help will be apprecieated and thanks in advance!
Zhefu
Question about string operation in epics db ? lzf neu
RE: Question about string operation in epics db ? Iain Marcuson
Prev: RE: Question about string operation in epics db ? Iain Marcuson
Next: RE: CSS binary color text Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: RE: Question about string operation in epics db ? Mooney, Tim M.
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
