Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Question about PV name by using pcaspy
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 29 Mar 2017 07:37:58 +0000
I want to fulfill a goal that when running camonitor command, PV name TEST:PING in the terminal window print "Disconnect!" or "OK!" alternatively.
However, I failed, "self.setParam('PING',a)"  seems only run once in the code and in terminal window only print one result.
I have posted the code in the following lines.
Could you give me some suggestions and any help will be appreciated.
Zhefu
#!/usr/bin/env python
import os
import threading
import time
from pcaspy import Driver, SimpleServer
prefix = 'TEST:'
pvdb = {
    'PING' : {
         'type':'enum',
         'enums':['Disconnect!','OK!']
class myDriver(Driver):
    def __init__(self):
        super(myDriver, self).__init__()
        tid=threading.Thread(target=self.determine)
        tid.setDaemon(True)
        tid.start()
    def determine(self):
        a=os.system("ping -c 1 -w 1 127.0.0.1")
        if (a==0):
          while True:
             a=not a
             time.sleep(5)
if __name__ == '__main__':
    server = SimpleServer()
    server.createPV(prefix, pvdb)
    driver = myDriver()
    # process CA transactions
    while True:
        server.process(0.1)
Re: Question about PV name by using pcaspy Kasemir, Kay
Prev: Re: INP string length Konrad, Martin
Next: Re: Question about PV name by using pcaspy Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: INP string length Michael Davidsaver
ANJ, 29 Mar 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
