1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: INP string length
To: "Konrad, Martin" <[email protected]>, "Siddons, David" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Mar 2017 10:33:04 -0400
On 03/28/2017 11:28 PM, Konrad, Martin wrote:
> Hi Pete,
> On 03/28/2017 10:51 PM, Siddons, David wrote:
>> Back in 2010 I found this comment from Michael Davidsaver:
>>> One of the limitations on the length of INP or OUT is dbPutString
>>> in dbStaticLib.c (search for 'string[80]').  When you reach this
>>> limit you will see the message "dbPutString received a string that
>>> is too long". Do you see this?
>> Well, yes, I do :) Has there been any changes in this behavior since
>> then?
> Yes. Search for "Raised limit on link field length in database files" in
> [1] for more details.
This length limitation is removed entirely in the 3.16 series.
Re: INP string length Konrad, Martin
Prev: Re: Question about PV name by using pcaspy Kasemir, Kay
Next: Re: memory leak after unloading of ca.lib Xiaoqiang Wang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: INP string length Konrad, Martin
Next: Question about PV name by using pcaspy lzf neu
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
