Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: 3.15 build rules suppress crash message [was: EPICS make problem]
From: Ben Franksen <benjamin.franksen@helmholtz-berlin.de>
To: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Wed, 8 Mar 2017 11:33:10 +0100
Am 08.03.2017 um 06:12 schrieb Torsten Bögershausen:
Can you extract the command line and run it by hand?
Yes. I do see that snc crashes with both versions of EPICS when I run
the command in my terminal.
(Just trying to be helpful. Michael already asked for the core file)
Otherwise you may be able to run the compiler under gdb ?!?
To re-iterate, the problem is not the crash itself which was easily
fixed and purely my fault. Sorry for being unclear on this point. I have
fixed the subject line accordingly.
The problem (and mystery!) is the absence of any message in the make
output under 3.15 that would indicate that snc crashed; whereas under
3.14 I do see such a message in the make output. I can reproduce this
behavior reliably, regardless of the -j and -s make switches. My
conclusion is that something was changed in the build system between
3.14 and 3.15 that causes the crash message ("segmentation fault (core
dumped)") to be suppressed, probably as an unintended side-effect.
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ralph Lange
EPICS make problem Benjamin Franksen
Re: EPICS make problem Torsten Bögershausen
Prev: Re: EPICS make problem Torsten Bögershausen
Next: Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 08 Mar 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
