1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS make problem
To: Benjamin Franksen <[email protected]>, EPICS Techtalk <[email protected]>
Date: Wed, 8 Mar 2017 06:12:25 +0100
Can you extract the command line and run it by hand?
(Just trying to be helpful. Michael already asked for the core file)
Otherwise you may be able to run the compiler under gdb ?!?
On 07/03/17 15:32, Benjamin Franksen wrote:
During development of the sequencer it may happen that the SNL compiler
(snc) crashes with a segmentation fault. With 3.14 this looks like
franksen@tiber: ...test/validate/O.linux-x86 > rm wait.*
franksen@tiber: ...test/validate/O.linux-x86 > make
make -f ../Makefile TOP=../../.. T_A=linux-x86  all
make[1]: Entering directory
`/home/franksen/src/seq/branch-2-3/home/test/validate/O.linux-x86'
perl /home/franksen/src/epics-base/3.14/bin/linux-x86/mkmf.pl -m
wait.st.d  .  ../os/Linux ../os/posix ../os/default ..  wait.i ../wait.st
make[1]: Leaving directory
preprocessing ../wait.st
/usr/bin/gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_
 -DUNIX  -Dlinux   -I. -I../O.Common -I. -I..
-I../../../include/os/Linux -I../../../include
-I/home/franksen/src/epics-base/3.14/include/os/Linux
-I/home/franksen/src/epics-base/3.14/include        ../wait.st > wait.i
compiling wait.i to C
/home/franksen/src/seq/branch-2-3/home/bin/linux-x86/snc   +m  wait.i -o
wait.c.tmp
make[1]: *** [wait.c] Segmentation fault (core dumped)
make: *** [all] Error 2
franksen@tiber: ...test/validate/O.linux-x86 > ll wait.*
-rw-rw-r-- 1 franksen franksen    0 Mär  7 15:14 wait.c.tmp
-rw-rw-r-- 1 franksen franksen 1707 Mär  7 15:14 wait.i
-rw-rw-r-- 1 franksen franksen   84 Mär  7 15:14 wait.st.d
Note the line
in the make output. Now with 3.15:
rm wait.*
compiling waitfun.i to C
/home/franksen/src/seq/branch-2-3/home/bin/linux-x86/snc   +m  waitfun.i
-o waitfun.c.tmp
 -DUNIX  -Dlinux   -I. -I../O.Common -I. -I. -I..
-I../../../include/compiler/gcc -I../../../include/os/Linux
-I../../../include
-I/home/franksen/src/epics-base/3.15/include/compiler/gcc
-I/home/franksen/src/epics-base/3.15/include/os/Linux
-I/home/franksen/src/epics-base/3.15/include        ../wait.st > wait.i
wait.c.tmp
perl -CSD /home/franksen/src/epics-base/3.15/bin/linux-x86/mkmf.pl -m
wait.st.d  .  ../compiler/gcc ../compiler/default .  ../os/Linux
-o waitfun.c.tmp
wait.c.tmp
-rw-rw-r-- 1 franksen franksen    0 Mär  7 15:24 wait.c.tmp
-rw-rw-r-- 1 franksen franksen 1707 Mär  7 15:24 wait.i
-rw-rw-r-- 1 franksen franksen   47 Mär  7 15:24 wait.st.d
Note: nothing about seg faults or dumped cores in the make output here.
I have not the slightest idea what could cause this.
I have checked (a) the environment (b) the MAKEFLAGS and (c) the command
line that invokes snc. They are exactly the same (apart from the
variable EPICS_BASE in the environment).
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
3.15 build rules suppress crash message [was: EPICS make problem] Ben Franksen
EPICS make problem Benjamin Franksen
Prev: stream device user variables Al Honey
Next: 3.15 build rules suppress crash message [was: EPICS make problem] Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS make problem Benjamin Franksen
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
