1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: CSS 4.3.x is not showing main help (Help Contents)
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 27 Feb 2017 16:09:38 +0000
Thanks for the prompt reply, Kay.
So the right way is to build my own product with relevant features/plugins added.
Tomas
Od: Kasemir, Kay [[email protected]]
Odesláno: 27. února 2017 15:12
Komu: Mazanec Tomáš; [email protected]
Předmět: Re: CSS 4.3.x is not showing main help (Help Contents)
Hi:
The Eclipse/CSS online help is displayed by a web browser that gets content from a Jetty web server. The JettyConfigurator is in the org.eclipse.equinox.http.jetty plugin.
One example for getting that into the product would be the SNS product, see sources and build instructions on https://github.com/ControlSystemStudio/org.csstudio.sns .
As for that specific help related plugin, the org.csstudio.sns/repository/basic-epics.product and sns-css.product each include org.csstudio.sns.feature.eclipse to get all the basic Eclipse plugins, including the org.eclipse.equinox.http.jetty plugin:
https://github.com/ControlSystemStudio/org.csstudio.sns/blob/master/features/org.csstudio.sns.feature.eclipse/feature.xml#L286
-Kay
From: [email protected] <[email protected]> on behalf of Mazanec Tomáš <[email protected]>
Sent: Sunday, February 26, 2017 6:17 PM
To: [email protected]
Subject: CSS 4.3.x is not showing main help (Help Contents)
Hi all
I'm trying to resolve this issue -- CSS 4.3.x doesn't run its main help from the menu: Help -> Help Contents.
And prints out the following message:
2017-02-26 22:48:06.953 SEVERE [Thread 1] org.csstudio.logging.PluginLogListener (logging) - Unhandled event loop exception
java.lang.NoClassDefFoundError: org/eclipse/equinox/http/jetty/JettyConfigurator
    at org.eclipse.help.internal.server.JettyHelpServer$StartServerThread.run(JettyHelpServer.java:78)
Caused by: java.lang.ClassNotFoundException: org.eclipse.equinox.http.jetty.JettyConfigurator cannot be found by org.eclipse.help.base_4.0.301.v20160212-1500
    at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:439)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
    at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
    ... 1 more
Regularly I use several update sites to add plugins to CSS:
http://download.controlsystemstudio.org/updates/4.3
http://download.eclipse.org/releases/mars
http://download.eclipse.org/eclipse/updates/4.5
CSS build in question is just a product build downloaded from http://controlsystemstudio.org/controlsystemstudio/current.html#
Well, org.eclipse.help.base is available from the update sites but jetty is not and it was not straightforward to find some update site.
Then I've tried update site listed on eclipse web http://download.eclipse.org/jetty/updates/jetty-bundles-9.x/ but there are other not resolved dependencies and I'm not completely sure about the right version of jetty.
So I'd rather to fix the problem in more systematic way and avoid experiments with third-party plugins and update-sites.
Is there a recommended way how to make the main Help of CSS working ?
Tomas
CSS 4.3.x is not showing main help (Help Contents) Mazanec Tomáš
Re: CSS 4.3.x is not showing main help (Help Contents) Kasemir, Kay
Prev: Thorlabs (PM100USB and PM16 series) Power Meters Michael Johnson
Next: Re: Thorlabs (PM100USB and PM16 series) Power Meters Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: CSS 4.3.x is not showing main help (Help Contents) Kasemir, Kay
Next: ubuntu 16.04 LTS + base3.15.5 "भावना नितिन मेढ़"
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
