Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: VAL field in Motor record Default unit
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Thu, 16 Feb 2017 12:13:25 +0000
Analog feedback with closed loop PID is a standard feature on the 4080 controller.  Though, it would work better with the 16 bit option.  Here are some useful Galil commands:
AF - Define analog feedback.  Uses uncommitted analog inputs
TE - Tell current error
OE - Off on error.  Define allowed following error before motor off.  Stop runaway
TC - Tell error code
BN - Burn settings to EEPROM
Analog feedback Galil command is not available through the Galil EPICS driver.  First set analog feedback in galilTools using AF, then burn settings to EEPROM.  Continue to configure the motor, and feedback in Galiltools, and burn settings when finished.  Once finished, the Galil EPICS driver 3-4 should work as normal.
The analog voltage is decoded into counts as per the ADC resolution, and range setting.
Good luck, and best,
Prev: EDM compiling problems lzf neu
Next: RE: Problem compiling areaDetector-2-5 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: VAL field in Motor record Default unit kathryn.baker
Next: Logbook entry error Patard Charles-Henri
ANJ, 16 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
