1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: EDM compiling problems
Date: Thu, 16 Feb 2017 08:34:53 +0000
I visit the directory /extensions/src/edm/setup/ and run ./setup.sh to compile EDM, an error occured and gives the following information:
Edm component file is /home/user/epics/extensions/src/edm/setup/edmObjects
/home/user/epics/extensions/src/edm/imagelib/O.linux-x86_64/lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory
When running EDM, the software cannot display pictures and gives the following error messages:
Error creating object "activePngClass"
Error creating object "cfcf6c8a_dbeb_11d2_8a97_00104b8742df"
However, I have already installed giflibgiflib-devellibNX_Xtst, libXtst, libXtst-devel packages and set env .
export EDMBASE=/home/user/epics/extensions/src/edm
export EDMPVOBJECTS=/home/user/epics/extensions/src/edm/setup
export EDMOBJECTS=/home/user/epics/extensions/src/edm/setup
export EDMHELPFILES=/home/user/epics/extensions/src/edm/helpFiles
export EDMFILES=/home/user/epics/extensions/src/edm/edmMain
Do I miss something?
Could you give me some advice thanks in advance.
Zhefu
Re: EDM compiling problems Mike Westfall
Prev: Re: IOC Connecting Problem Florian Feldbauer
Next: RE: VAL field in Motor record Default unit Mark Clift
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: RE: RE: RE: RE: Re: IOC Connecting Problem Pilkyu Jung
Next: Re: EDM compiling problems Mike Westfall
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
