1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Default value to field SCAN
To: Gabriel de Souza Fedel <[email protected]>
Date: Tue, 3 Jan 2017 09:31:35 -0300
 Gabriel, the default value for the SCAN field is zero, or "Passive":
https://github.com/epics-base/epics-base/blob/3.16/src/ioc/db/menuScan.dbd
 To change this default value, use either field(SCAN, "value") on the
record definition, or do a caput on the SCAN PV:
 record(abcd, xyz) {
   field(SCAN, ".1 second")
 The message you are seeing is a symptom to some record or device
support problem. Note that all the necessary threads for all the scan
periods are always created:
https://github.com/epics-base/epics-base/blob/3.16/src/ioc/db/dbScan.c#L184
2017-01-03 8:57 GMT-03:00 Gabriel de Souza Fedel <[email protected]>:
> Hi,
> When I create records and don't set the field SCAN, what is the default
> value? There is an way to change this?
> I'm having problems with a set of records without SCAN field that are
> consuming a lot of CPU, and receiving this messages:
> dbScan warning from '.2 second' scan thread:
>         Scan processing averages 0,00 seconds (0,00 .. 0,02).
>         Over-runs have now happened 283681 times in a row.
>         To fix this, move some records to a slower scan rate.
> dbScan warning from '.5 second' scan thread:
>         Scan processing averages 0,00 seconds (0,00 .. 0,03).
>         Over-runs have now happened 290049 times in a row.
> dbScan warning from '.1 second' scan thread:
>         Over-runs have now happened 278431 times in a row.
> If i remove small choices from dbd file (.1, .2 and .5 seconds) solves the
> problem. Apparently the records are being created with all SCAN
> values...some idea to solve this?
> Regards,
> Gabriel Fedel
> Software de Operação das Linhas de Luz
> Laboratório Nacional de Luz Síncrotron – (LNLS)
> Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
> [email protected] | +55 (19) 3512 1226
> www.lnls.cnpem.br
Default value to field SCAN Gabriel de Souza Fedel
Prev: Default value to field SCAN Gabriel de Souza Fedel
Next: Re: Asyn support Stefen Paul
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: RE: Default value to field SCAN Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
