When I create records and don't set the field SCAN, what is the default
value? There is an way to change this?
I'm having problems with a set of records without SCAN field that are
consuming a lot of CPU, and receiving this messages:
dbScan warning from '.2 second' scan thread:
Scan processing averages 0,00 seconds (0,00 .. 0,02).
Over-runs have now happened 283681 times in a row.
To fix this, move some records to a slower scan rate.
dbScan warning from '.5 second' scan thread:
Scan processing averages 0,00 seconds (0,00 .. 0,03).
Over-runs have now happened 290049 times in a row.
dbScan warning from '.1 second' scan thread:
Over-runs have now happened 278431 times in a row.
If i remove small choices from dbd file (.1, .2 and .5 seconds) solves
the problem. Apparently the records are being created with all SCAN
values...some idea to solve this?
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
- Re: Default value to field SCAN Henrique Almeida
- RE: Default value to field SCAN Mark Rivers
- Re: Default value to field SCAN Andrew Johnson
Re: Asyn support Stefen Paul
<2017>
RE: Installing areadetector on raspberry-pi2 OS raspbian pixels Mark Rivers
<2017>
