Subject: |
Philosophy regarding use of open source libraries for EPICS |
Rod Nussbaumer <[email protected]> |
To: |
epics Techtalk <[email protected]> |
Date: |
Wed, 16 Nov 2016 07:43:36 -0800 |
All:
I would like to get peoples' opinions about the right way to deal with
open source third party libraries that get bound to EPICS applications,
particularly on Linux, but wherever else it comes into play. An example
case would be libgif, which can be used by EDM to display GIF images in
EDM screens. The Area Detector package seems to make significant use of
such libraries for image processing. So far, the standard procedure here
has been to install the libraries from binary repositories supported by
OS vendors such as Redhat, Debian, etc. We do this on development hosts
and the matching production host architectures. However, this leaves us
vulnerable to incompatible changes that may be introduced due to routine
maintenance of the hosts, and silently changes the deployed EPICS
software with no knowledge of the effect, or testing that it works as
expected. The alternative would be to build from sources, all libraries
that go into an EPICS application, and install the lib binaries in a way
that they get used in lieue of the system-installed packages. Does
anyone do that? Am I being paranoid? The obvious question is how far
would you take this approach, since literally everything binds to libc,
libm, and some other standard libraries.
Thanks in advance for your opinions.
Rod Nussbaumer
TRIUMF
Vancouver, Canada
- Re: Philosophy regarding use of open source libraries for EPICS Kasemir, Kay
- RE: Philosophy regarding use of open source libraries for EPICS Mark Rivers
- Re: Philosophy regarding use of open source libraries for EPICS J. Lewis Muir
- Re: Philosophy regarding use of open source libraries for EPICS Bruce Hill
RE: OS X edm/medm openmotif woes Jemian, Pete R.
<2016>
RE: IOC for keithley 6485 using asyn Mark Rivers
<2016>
ANJ, 16 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
