No. In this case, on-demand means when a person chooses to execute the "make" command in the directory with the changed .adl file(s).
Sent from a device with a dreadfully small screen
-------- Original message -------- From: Rod Nussbaumer <[email protected]> Date: 11/16/16 9:24 AM (GMT-06:00) To: [email protected] Subject: Re: OS X edm/medm openmotif woes Pete:
Does 'on-demand scripted conversion' mean that the conversion takes place immediately before the screen is displayed, and as often as the screen is displayed? I presume that this requires some built-in support from caQtDM to accomplish this? Rod Nussbaumer TRIUMF, Vancouver, Canada On 11/16/2016 06:30 AM, Pete Jemian wrote: > The workflow BCDA is using to support its beam lines at the APS to > transition from MEDM to caQtDM is > > 1. implement on-demand scripted conversion from .adl to .ui files > 2. beam lines to use caQtDM when screens are ready > 3. continue to edit screens as .adl files during transition > and convert to .ui (choices managed by a Makefile rule) > 4. train facility staff to use Qt Designer > 5. edit screens in Qt Designer > 6. discontinue MEDM altogether > > Hope to complete that by spring 2017 >
ANJ, 16 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
