Is it expected that either of the latest 3.14 or 3.15 releases should build against RTEMS 4.11 ? Trying with 3.15.5-rc1 and RTEMS 4.11 I get the following error below. I'm using the beatnik, mvme2307 and mvme3100 bsp's. FWIW, 3.15.5-rc1 builds fine against RTEMS 4.10. -Matt <snip> ... make[3]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom/O.RTEMS-beatnik' make[3]: Entering directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom/O.RTEMS-beatnik' Installing generic include file /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS/osiFileName.h mkdir /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS Installing generic include file /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS/osdSock.h <snip> ... /gem_sw/targetOS/RTEMS/rtems-4.11/bin/powerpc-rtems4.11-gcc --pipe -B/gem_sw/targetOS/RTEMS/rtems-4.11/powerpc-rtems4.11/beatnik/lib/ -specs bsp_specs -qrtems -fa sm -mcpu=7400 -D__ppc_generic -DUNIX -O2 -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEM S_NETWORK_CONFIG_CLUSTER_SPACE=5120 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l ibCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../ src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLi b -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/ gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom /pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCo m/yajl -I/gem_sw/epics/R3.15.5-rc1/base/include/compiler/gcc -I/gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS -I/gem_sw/epics/R3.15.5-rc1/base/include -c . ./../../src/libCom/osi/os/RTEMS/osdPoolStatus.c ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c: In function 'osiSufficentSpaceInPool': ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:20:5: error: unknown type name 'rtems_malloc_statistics_t' rtems_malloc_statistics_t s; ^ ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:23:5: warning: implicit declaration of function 'malloc_get_statistics' [-Wimplicit-function-declaration] malloc_get_statistics(&s); ^ ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:10: error: request for member 'space_available' in something not a structure or union n = s.space_available - (unsigned long)(s.lifetime_allocated - s.lifetime_freed); ^ ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:46: error: request for member 'lifetime_allocated' in something not a structure or union n = s.space_available - (unsigned long)(s.lifetime_allocated - s.lifetime_freed); ^ ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:69: error: request for member 'lifetime_freed' in something not a structure or union n = s.space_available - (unsigned long)(s.lifetime_allocated - s.lifetime_freed); ^ make[3]: *** [osdPoolStatus.o] Error 1 make[3]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom/O.RTEMS-beatnik' make[2]: *** [install.RTEMS-beatnik] Error 2 make[2]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom' make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src' make: *** [src.install] Error 2 On Mon, Oct 31, 2016 at 1:05 PM, Andrew Johnson <[email protected]> wrote: Ralph Lange and I have today tagged and generated Release Candidate[1]
ANJ, 07 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
