1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS V4 question
To: Mark Rivers <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Sun, 9 Oct 2016 18:49:52 -0400
On 10/09/2016 06:16 PM, Mark Rivers wrote:
> Hi Michael,
> Thanks for the quick response.
> I have another newbie question.
> My class has
> private:
>     std::string m_pvName;
>     std::string m_request;
>     short m_priority;
>     ChannelProviderPtr m_provider;
>     ChannelPtr m_channel;
> How do I initialize m_channel in my constructor so that I know that
>   m_channel = m_provider->createChannel(m_pvName, m_thisPtr, m_priority);
> has not yet been call, so I should not call m_channel->destroy()?  If this were a normal pointer I would initialize it to 0 and test that, but that does not work for a ChannelPtr.
> If I unconditionally call m->channel->destroy() before m_channel has been created the first time I get an access violation.
You should do just what you would with a plain pointer in the ctor.  The
difference is that instead of initializing with 'm_channel(0)', just do
'm_channel()'.  The default ctor for shared_ptr initializes to NULL.
then for cleanup:
> if(m->channel) m->channel->destroy()
An important note is that shared_ptr does *not* protect you from races
when changing the pointer.  So what I would do is the following with a
mutex which guards 'm_channel', but isn't held for destory() or the
dtor, which avoid even the possibility of lock order bugs.
>   ChannelPtr temp; // aka. shared_ptr<Channel>
>      Guard G(somemutex); // aka. epicsGuard<epicsMutex>
>      temp.swap(m_channel);
>   if(temp) temp->destory();
>   // temp goes out of scope and Channel dtor runs
> Thanks,
> Mark
> From: Michael Davidsaver [[email protected]]
> Sent: Sunday, October 09, 2016 1:37 PM
> To: Mark Rivers; EPICS Tech-Talk
> Mark,
> First, the *Requester classes are somewhat "transient", so it's probably
> not a good idea to combine this with ADDriver, which isn't.  You may
> also get into trouble should you wish to have one ADDriver associated
> with more than on PVA channel (as you have inadvertently done).
> Disconnecting is done with Channel::destory(), not the ChannelRequester.
>  For various annoying reasons it is *not* sufficient to let a connected
> Channel be destroyed (as in c++ destructor).  Calling Channel::destory()
> is mandatory.
> You may (or not) find the following test code useful in understanding
> the Channel/Monitor lifecycle.
> https://github.com/mdavidsaver/pva2pva/blob/master/testApp/testtest.cpp
> Michael
> On 10/09/2016 01:24 PM, Mark Rivers wrote:
>> I have some EPICS V4 client code that basically does the following:
>> class epicsShareClass pvaDriver : public ADDriver,
>>         public virtual epics::pvAccess::ChannelRequester,
>>         public virtual epics::pvData::MonitorRequester
>>     try
>>         ClientFactory::start();
>>         m_provider = getChannelProviderRegistry()->getProvider("pva");
>> m_priority);
>>         m_pvRequest = CreateRequest::create()->createRequest(m_request);
>>         m_monitor = m_channel->createMonitor(m_thisPtr, m_pvRequest);
>>     catch (exception &ex)
>> The monitorConnect() and monitorEvent() methods are being called as
>> expected, and everything is working.
>> Now I want to extend the code to allow the current channel to be
>> disconnected, and call m_provider->createChannel() to a different
>> channel.  What do I need to do for this?  I found that if I just call
>> m_provider->createChannel with a different p_pvName it does not throw an
>> exception, but it appears to simply stay connected to the existing channel.
>> Thanks,
>> Mark
RE: EPICS V4 question Mark Rivers
Re: EPICS V4 question Michael Davidsaver
Prev: RE: EPICS V4 question Mark Rivers
Next: RE: EPICS V4 question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 09 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
