Hi Michael,
Great thanks it's working now. This is the pvaDriver that Bruno Martins wrote. I've just added some features:
- Implements ADAcquire, ADImageMode, ADNumImages. So acquisition can be started and stopped, and can be
done in Single, Multiple, or Continuous mode
- New PvName PV allows changing the EPICS V4 PV name at runtime, so it can switch between receiving arrays
from different servers (that's what your help was for)
- Added medm screens for pvaDriver and NDPluginPVA
- Implements autosave
The new version is in the master branch of ADCore and ADExample on github.
Sent: Sunday, October 09, 2016 5:49 PM
To: Mark Rivers; EPICS Tech-Talk
Subject: Re: EPICS V4 question
On 10/09/2016 06:16 PM, Mark Rivers wrote:
> Hi Michael,
> Thanks for the quick response.
> I have another newbie question.
> My class has
> private:
> std::string m_pvName;
> std::string m_request;
> short m_priority;
> ChannelProviderPtr m_provider;
> ChannelPtr m_channel;
> How do I initialize m_channel in my constructor so that I know that
> m_channel = m_provider->createChannel(m_pvName, m_thisPtr, m_priority);
> has not yet been call, so I should not call m_channel->destroy()? If this were a normal pointer I would initialize it to 0 and test that, but that does not work for a ChannelPtr.
> If I unconditionally call m->channel->destroy() before m_channel has been created the first time I get an access violation.
You should do just what you would with a plain pointer in the ctor. The
difference is that instead of initializing with 'm_channel(0)', just do
'm_channel()'. The default ctor for shared_ptr initializes to NULL.
then for cleanup:
> if(m->channel) m->channel->destroy()
An important note is that shared_ptr does *not* protect you from races
when changing the pointer. So what I would do is the following with a
mutex which guards 'm_channel', but isn't held for destory() or the
dtor, which avoid even the possibility of lock order bugs.
> ChannelPtr temp; // aka. shared_ptr<Channel>
> Guard G(somemutex); // aka. epicsGuard<epicsMutex>
> temp.swap(m_channel);
> if(temp) temp->destory();
> // temp goes out of scope and Channel dtor runs
> Thanks,
> Mark
> From: Michael Davidsaver [[email protected]]
> Sent: Sunday, October 09, 2016 1:37 PM
> Mark,
> First, the *Requester classes are somewhat "transient", so it's probably
> not a good idea to combine this with ADDriver, which isn't. You may
> also get into trouble should you wish to have one ADDriver associated
> with more than on PVA channel (as you have inadvertently done).
> Disconnecting is done with Channel::destory(), not the ChannelRequester.
> For various annoying reasons it is *not* sufficient to let a connected
> Channel be destroyed (as in c++ destructor). Calling Channel::destory()
> is mandatory.
> You may (or not) find the following test code useful in understanding
> the Channel/Monitor lifecycle.
> https://github.com/mdavidsaver/pva2pva/blob/master/testApp/testtest.cpp
> Michael
> On 10/09/2016 01:24 PM, Mark Rivers wrote:
>> I have some EPICS V4 client code that basically does the following:
>> class epicsShareClass pvaDriver : public ADDriver,
>> public virtual epics::pvAccess::ChannelRequester,
>> public virtual epics::pvData::MonitorRequester
>> try
>> ClientFactory::start();
>> m_provider = getChannelProviderRegistry()->getProvider("pva");
>> m_priority);
>> m_pvRequest = CreateRequest::create()->createRequest(m_request);
>> m_monitor = m_channel->createMonitor(m_thisPtr, m_pvRequest);
>> catch (exception &ex)
>> The monitorConnect() and monitorEvent() methods are being called as
>> expected, and everything is working.
>> Now I want to extend the code to allow the current channel to be
>> disconnected, and call m_provider->createChannel() to a different
>> channel. What do I need to do for this? I found that if I just call
>> m_provider->createChannel with a different p_pvName it does not throw an
>> exception, but it appears to simply stay connected to the existing channel.
>> Thanks,
>> Mark
- EPICS V4 question Mark Rivers
- Re: EPICS V4 question Michael Davidsaver
- RE: EPICS V4 question Mark Rivers
CSS 4.33 / Mars 4.5.2 / BOY not found Alex Squitieri
<2016>
Re: EPICS V4 question Benjamin Franksen
<2016>
