I understand,sir and thank you for recommendation. However, the thing is that whenever I try to make a simple example, the program can't read the database file (just I wrote at the first message <No such file or directory dbRead opening ..> . You said that they don't come with EPICS BASE, then I try to make a simple example which includes the same records but at this time both are digital. I also try to write protocol file (arduino.proto) . That's OK so far. In somehow, when I tend to write database file (.db) and direct the path of that (.db) in the "st.cmd" file, I've got an error which says that Record initialised not correctly.. I also tried to make the same example by using VDCT. In ai and ao records, I set the DTYP as stream ( but, by default there is no option in VDCT). I've got the same error . However, when i say genaretes macros in VDCT (it put a script in .db file like this (template { } )). At this time, I've got an error exactly the same as I wrote the first message. I thougt, the problem may be caused by PORT definitions,maybe the program can't connect the data. But, I did the exactly same things in examples. Thanks in advance.. Best Regards.. 2016-07-26 0:29 GMT+03:00 Mark Rivers <[email protected]>:
ANJ, 27 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
