Hi Everyone,
I have just been dealing with EPICS and its applications since a few weeks. I've done basic things such as creating IOC, making MEDM display,communicating Octave and etc..And I've got help most of the time in this tech-talk. I am now dealing with communication a device that is supported by EPICS. I have got a Digitizier which is manufactured by CAEN. But before I deal with that device, I want to figure out the database configuration in an application. Therefore, I research on the Internet and in this website. I found a quite basic example which is : I've just done the previous sections of this example,and also followed the steps in that link. However, when I run it I've got nothing. More specifically : #!/opt/epics/helloWorldIOC/bin/linux-x86_64/helloWorldIOC ## You may have to change helloWorldIOC to something else ## everywhere it appears in this file #< envPaths epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db") ## Register all support components dbLoadDatabase("../../dbd/helloWorldIOC.dbd",0,0) helloWorldIOC_registerRecordDeviceDriver(pdbbase) drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyACM0",0,0,0) asynSetOption("SERIALPORT",-1,"baud","115200") asynSetOption("SERIALPORT",-1,"bits","8") asynSetOption("SERIALPORT",-1,"parity","none") asynSetOption("SERIALPORT",-1,"stop","1") asynSetOption("SERIALPORT",-1,"clocal","Y") asynSetOption("SERIALPORT",-1,"crtscts","N") dbLoadRecords("db/arduino.db","PORT='SERIALPORT'") filename="../dbLexRoutines.c" line number=240 No such file or directory dbRead opening file db/arduino.db ## Load record instances dbLoadRecords("/opt/epics/helloWorld/db/helloWorldIOC.db","user=hulusi") filename="../dbLexRoutines.c" line number=240 No such file or directory dbRead opening file /opt/epics/helloWorld/db/helloWorldIOC.db iocInit() Starting iocInit ############################################################################ ## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$ ## EPICS Base built Jul 21 2016 ############################################################################ iocRun: All initialization complete ## Start any sequence programs #seq snchelloWorldIOC,"user=hulusi" I guess, the problem is due to the colored line in this output. But I'm not sure that. Is it so ? If it is like that, how can I figure it out ? If it isn't like that, what does the thing cause this problem ? Thanks in advance.. Best regards.. Hulusi
ANJ, 28 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
