I just tried to reproduce your problem.
I built base-3.15.3, asyn 4-28 and stream (tag synApps_5_8).
I then followed the instructions here:
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-29/HowToDoSerial/HowToDoSerial_StreamDevice.html
It worked fine except for one thing. I needed to change these lines in HPE3631ASup/Makefile:
DB_INSTALLS += devHPE3631A.db
DB_INSTALLS += $(TOP)/HPE3631ASup/devHPE3631A.proto
to
DB += devHPE3631A.db
DB += $(TOP)/HPE3631ASup/devHPE3631A.proto
This is the output when I run make in the example HPE3631A directory created following the instructions above.
corvette:~/scratch/HPE3631A>make
make -C ./configure install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/configure'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/configure/O.linux-x86_64'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/configure'
make -C ./HPE3631ASup install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631ASup'
mkdir O.Common
make[2]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631ASup/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631ASup/O.linux-x86_64'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631ASup'
make -C ./HPE3631AtestApp install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp'
make -C ./src install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src/O.linux-x86_64'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc
-I../../../include/os/Linux -I../../../include -I/home/epics/scratch/asyn/include -I/home/epics/scratch/stream/include -I/usr/local/epics/base-3.15.3/include/compiler/gcc -I/usr/local/epics/base-3.15.3/include/os/Linux -I/usr/local/epics/base-3.15.3/include
-MM -MF HPE3631AtestMain.d ../HPE3631AtestMain.cpp
Creating dbd file HPE3631Atest.dbd
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/epics/scratch/asyn/dbd -I/home/epics/scratch/stream/dbd -I/usr/local/epics/base-3.15.3/dbd
-o HPE3631Atest.dbd base.dbd stream.dbd asyn.dbd drvAsynSerialPort.dbd
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/epics/scratch/asyn/dbd -I/home/epics/scratch/stream/dbd
-I/usr/local/epics/base-3.15.3/dbd -o HPE3631Atest_registerRecordDeviceDriver.cpp ../O.Common/HPE3631Atest.dbd HPE3631Atest_registerRecordDeviceDriver /home/epics/scratch/HPE3631A
-MM -MF HPE3631Atest_registerRecordDeviceDriver.d HPE3631Atest_registerRecordDeviceDriver.cpp
make[3]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src/O.linux-x86_64'
Installing created dbd file ../../../dbd/HPE3631Atest.dbd
-c HPE3631Atest_registerRecordDeviceDriver.cpp
-c ../HPE3631AtestMain.cpp
/usr/bin/g++ -o HPE3631Atest -L/home/epics/scratch/asyn/lib/linux-x86_64 -L/home/epics/scratch/stream/lib/linux-x86_64 -L/usr/local/epics/base-3.15.3/lib/linux-x86_64 -Wl,-rpath,/home/epics/scratch/asyn/lib/linux-x86_64
-Wl,-rpath,/home/epics/scratch/stream/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-3.15.3/lib/linux-x86_64 -rdynamic -m64 HPE3631Atest_registerRecordDeviceDriver.o HPE3631AtestMain.o -ldbRecStd -ldbCore -lca -lCom -lstream -lasyn
Installing created executable ../../../bin/linux-x86_64/HPE3631Atest
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/src'
make -C ./Db install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db'
mkdir O.Common
make[3]: Entering directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db/O.linux-x86_64'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db/O.linux-x86_64'
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp/Db'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/HPE3631AtestApp'
make -C ./iocBoot install
make[1]: Entering directory `/home/epics/scratch/HPE3631A/iocBoot'
make -C ./iocHPE3631Atest install
make[2]: Entering directory `/home/epics/scratch/HPE3631A/iocBoot/iocHPE3631Atest'
perl -CSD /usr/local/epics/base-3.15.3/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/epics/scratch/HPE3631A envPaths
make[2]: Leaving directory `/home/epics/scratch/HPE3631A/iocBoot/iocHPE3631Atest'
make[1]: Leaving directory `/home/epics/scratch/HPE3631A/iocBoot'
It seems to me that you must have made a typo or some other error.
On Behalf Of l123173
Sent: Wednesday, July 06, 2016 7:38 AM
To: [email protected]
Subject: error when i do as howtodoserial_stramdevice.html said
Hi all,
I used base3.15.3, synApps_5_8, Fedora 23 (64) for epics.
I want to do the serial control as HowToDoSerial_StreamDevice.html in the ASYN document directory.
I try to do it as the tutorial( howto do serail_streamdevce.html ) said. But I failed and again and again.
The same error and I think it is beyond what I know.
Could you tell me how to fix it?
Regards
Li Xing
Here is the information.
[root@bogon kohzu2]# make
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.tapfiles.linux-x86_64' given more than once in the same rule
make[1]: Entering directory '/home/lyx/kohzu2/configure'
/opt/epics/base/configure/RULES_ARCHS:60: target 'inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:64: target 'linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:69: target 'O.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:85: target 'clean.linux-x86_64' given more than once in the same rule
perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make[1]: Circular install.linux-x86_64 <- install.linux-x86_64 dependency dropped.
make[2]: Entering directory '/home/lyx/kohzu2/configure/O.linux-x86_64'
perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/lyx/kohzu2/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/lyx/kohzu2/configure'
make -C ./KOHZUSup install
make[1]: Entering directory '/home/lyx/kohzu2/KOHZUSup'
mkdir O.Common
make[2]: Entering directory '/home/lyx/kohzu2/KOHZUSup/O.linux-x86_64'
make[2]: *** No rule to make target 'devKOHZU.db', needed by '../../db/devKOHZU.db'. Stop.
make[2]: Leaving directory '/home/lyx/kohzu2/KOHZUSup/O.linux-x86_64'
/opt/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/lyx/kohzu2/KOHZUSup'
/opt/epics/base/configure/RULES_DIRS:88: recipe for target 'KOHZUSup.install' failed
make: *** [KOHZUSup.install] Error 2
[root@bogon kohzu2]# Entering directory '/home/lyx/kohzu2/configure'
bash: Entering: command not found...
[root@bogon kohzu2]# /opt/epics/base/confi Entering directory '/home/lyx/kohzu2/configure'
bash: /opt/epics/base/confi: No such file or directory
