1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: error when i do as howtodoserial_stramdevice.html said
To: [email protected]
Date: Wed, 6 Jul 2016 20:38:18 +0800 (CST)
Hi all,
     I used base3.15.3, synApps_5_8, Fedora 23 (64) for epics.
     I want to do the serial control as HowToDoSerial_StreamDevice.html  in the ASYN document directory.
     I try to do it as the tutorial(  howto do serail_streamdevce.html ) said. But I failed and again and again.
     The same error  and I think it is beyond what I know.
     Could you tell me how to fix it?
Regards
Li Xing
Here is the information.
[root@bogon kohzu2]# make
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'configure.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUSup.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'KOHZUApp.tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.clean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.realclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.archclean.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_DIRS:87: target 'iocBoot.tapfiles.linux-x86_64' given more than once in the same rule
make -C ./configure install
make[1]: Entering directory '/home/lyx/kohzu2/configure'
/opt/epics/base/configure/RULES_ARCHS:60: target 'inc.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'build.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'install.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'buildInstall.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'runtests.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:60: target 'tapfiles.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:64: target 'linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:69: target 'O.linux-x86_64' given more than once in the same rule
/opt/epics/base/configure/RULES_ARCHS:85: target 'clean.linux-x86_64' given more than once in the same rule
perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make[1]: Circular install.linux-x86_64 <- install.linux-x86_64 dependency dropped.
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/lyx/kohzu2/configure/O.linux-x86_64'
perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/lyx/kohzu2/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/lyx/kohzu2/configure'
make -C ./KOHZUSup install
make[1]: Entering directory '/home/lyx/kohzu2/KOHZUSup'
mkdir O.Common
make[2]: Entering directory '/home/lyx/kohzu2/KOHZUSup/O.linux-x86_64'
make[2]: *** No rule to make target 'devKOHZU.db', needed by '../../db/devKOHZU.db'.  Stop.
make[2]: Leaving directory '/home/lyx/kohzu2/KOHZUSup/O.linux-x86_64'
/opt/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/lyx/kohzu2/KOHZUSup'
/opt/epics/base/configure/RULES_DIRS:88: recipe for target 'KOHZUSup.install' failed
make: *** [KOHZUSup.install] Error 2
[root@bogon kohzu2]#  Entering directory '/home/lyx/kohzu2/configure'
bash: Entering: command not found...
[root@bogon kohzu2]# /opt/epics/base/confi Entering directory '/home/lyx/kohzu2/configure'
bash: /opt/epics/base/confi: No such file or directory
RE: error when i do as howtodoserial_stramdevice.html said Mark Rivers
Prev: Re: MRF EVG, EVR, and EVM's Linux Kernel modules Michael Davidsaver
Next: RE: error when i do as howtodoserial_stramdevice.html said Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Question on CAEN SY4527 Jiro Fujita
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
