Dear Shantonu,
The new Channel Access event type flag DBE_PROPERTY was
introduced in EPICS 3.14.11, but proper support for the EPICS
records is only available in the EPICS 3.15 series.
I do not have a good idea about how CS-Studio, BOY and CAJ are
supporting this feature. I was prompting you for the versions,
hoping that one of the CS-Studio people would pick your question
up. (With the version numbers, they should be able to give an
answer.)
Sorry...
~Ralph
On 07/06/2016 13:23, Shantonu Sahoo
wrote:
Dear Ralph,
Can you tell me the exact versions of EPICS base, CSS and
CAJ in which this feature is incorporated.
Shantonu Sahoo
वैज्ञानिक अधिकारी / Scientific Officer
कंप्यूटर एवं सूचना वर्ग / Computer and Informatics Group
परिवर्ती ऊर्जा साइक्लोट्रॉन केन्द्र / Variable Energy
Cyclotron Center
Ph: (033) 23182300
[email protected] wrote:
To: Ralph Lange <[email protected]>
Sent by: [email protected]
Date: 06/06/2016 03:27PM
Cc: EPICS Tech-Talk <[email protected]>
Subject: Re: Problem in updating EGU field in CSS-BOY
I am using EPICS base-3.14.12.5, CS-Studio 4.1.4 ,
Java Utilities 3.2.0. I am not sure about the version
of CAJ. I am not using EPICS CA Gateway.
Shantonu Sahoo
Group
Cyclotron Center
Ph: (033) 23182300
-----Ralph Lange
<[email protected]> wrote: -----
To: EPICS Tech-Talk
<[email protected]>
Date: 06/06/2016 02:19PM
Cc: Shantonu Sahoo <[email protected]>
CSS-BOY
A feature to allow such updates of metadata has
been added to EPICS Base and the Channel Access
protocol recently.
What versions of EPICS Base (your IOC), CS-Studio
(your client) and CAJ (the Java CA client library
inside CS-Studio) are you using? Is there an EPICS
CA Gateway involved? (If yes, what version?)
~Ralph
On 06/06/2016 10:29,
Shantonu Sahoo wrote:
I am using CSS-BOY to display a process
variable using "Text Update". I have checked
the "Show Units" property. So, in addition to
the VALue, it displays the string that is
specified in the EGU field of the record. But,
in the runtime, if the EGU field changes, it
is not updated in the OPI until I do "Refresh
OPI". In contrary, the VALue is updated
smoothly.
Shantonu Sahoo
Informatics Group
Energy Cyclotron Center
Ph: (033) 23182300
- Re: Problem in updating EGU field in CSS-BOY Kasemir, Kay
- Re: Problem in updating EGU field in CSS-BOY Shantonu Sahoo
- Re: Problem in updating EGU field in CSS-BOY Ralph Lange
- Problem in updating EGU field in CSS-BOY Shantonu Sahoo
Re: motor:rrbv Torsten Bögershausen
Re: motor: rval/lrvl double or long ? Dirk Zimoch
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
