1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem in updating EGU field in CSS-BOY
To: Ralph Lange <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 6 Jun 2016 15:23:03 +0530
I am using EPICS base-3.14.12.5, CS-Studio 4.1.4 , Java Utilities 3.2.0. I am not sure about the version of CAJ. I am not using EPICS CA Gateway.
Shantonu Sahoo
वैज्ञानिक अधिकारी / Scientific Officer
कंप्यूटर एवं सूचना वर्ग / Computer and Informatics Group
परिवर्ती ऊर्जा साइक्लोट्रॉन केन्द्र / Variable Energy Cyclotron Center
Ph: (033) 23182300
-----Ralph Lange <[email protected]> wrote: -----
To: EPICS Tech-Talk <[email protected]>
Date: 06/06/2016 02:19PM
Cc: Shantonu Sahoo <[email protected]>
A feature to allow such updates of metadata has been added to EPICS Base and the Channel Access protocol recently.
What versions of EPICS Base (your IOC), CS-Studio (your client) and CAJ (the Java CA client library inside CS-Studio) are you using? Is there an EPICS CA Gateway involved? (If yes, what version?)
~Ralph
On 06/06/2016 10:29, Shantonu Sahoo wrote:
I am using CSS-BOY to display a process variable using "Text Update". I have checked the "Show Units" property. So, in addition to the VALue, it displays the string that is specified in the EGU field of the record. But, in the runtime, if the EGU field changes, it is not updated in the OPI until I do "Refresh OPI". In contrary, the VALue is updated smoothly.
Shantonu Sahoo
Ph: (033) 23182300
Re: Problem in updating EGU field in CSS-BOY Ralph Lange
Problem in updating EGU field in CSS-BOY Shantonu Sahoo
Prev: Re: Problem in updating EGU field in CSS-BOY Ralph Lange
Next: Re: PCASpy 0.6 Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Problem in updating EGU field in CSS-BOY Ralph Lange
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
