> Redirection works only for up to 4 values read in (3 redirections).
Not certain about that limit.
Here's an example that parses 6 values from the USB port.
With this combination (plus others):
host arch = linux-arm
base-3.15.3/
synApps_5_8/
stream-2-6a/
asyn-R4-29/
protocol
-----------% snip here %-----------
Terminator = CR LF;
#Terminator = LF;
# silence most error messages
IGNORE_THIS = "#*";
@mismatch { in $IGNORE_THIS; }
ExtraInput = Ignore;
report {
in "%(\$1:temperature.VAL)f"
"\t"
"%(\$1:humidity.VAL)f"
"\t"
"%(\$1:T:DHT11.VAL)f"
"\t"
"%(\$1:T:HI.VAL)f"
"\t"
"%(\$1:distance.VAL)f"
"\t"
"%(\$1:delta_t:us.VAL)d";
database
# received on USB port:
# NTC RH T HI dist delta_t
# 23.0 37 24 23.40 2480.1 5000668
record (stringin, "$(P)reader")
field (DTYP, "stream")
field (INP, "@protocol report(ioc:mega) $(PORT)")
field (SCAN, "I/O Intr")
#field (FLNK, "$(P)temperature")
record (ai, "$(P)temperature")
field (DESC, "thermistor, NTC")
field (PREC, "1")
field (EGU, "C")
#field (FLNK, "$(P)humidity")
record (ai, "$(P)humidity")
field (DESC, "relative humidity, DHT11")
field (PREC, "1")
field (EGU, "%")
#field (FLNK, "$(P)T:DHT11")
record (ai, "$(P)T:DHT11")
field (DESC, "temperature, DHT11")
field (PREC, "1")
field (EGU, "C")
#field (FLNK, "$(P)T:HI")
record (ai, "$(P)T:HI")
field (DESC, "heat index, DHT11")
field (PREC, "1")
field (EGU, "C")
#field (FLNK, "$(P)distance")
record (ai, "$(P)distance")
field (DESC, "distance, HC-SR04")
field (PREC, "1")
field (EGU, "mm")
#field (FLNK, "$(P)delta_t:us")
record (ai, "$(P)delta_t:us")
field (DESC, "reporting interval, us")
field (PREC, "6")
field (EGU, "us")
field (FLNK, "$(P)delta_t:calc")
record (calcout, "$(P)delta_t:calc")
field (PREC, "6")
field (EGU, "s")
field (INPA, "$(P)delta_t:us PP MS")
field (CALC, "A*1e-6")
field (OUT, "$(P)delta_t")
field (FLNK, "$(P)delta_t")
record (ai, "$(P)delta_t")
field (PREC, "6")
field (EGU, "s")
# process this record to reload all stream protocols
record (sub, "$(P)reload")
field (SNAM, "streamReload")
On 4/28/2016 11:20 AM, Gofron, Kazimierz wrote:
> Hi Yuliang,
At least that is what I am seeing when increasing number of redirections.
> Kaz
> -----Original Message-----
> From: Zhang Yuliang [mailto:[email protected]]
> Sent: Thursday, April 28, 2016 4:33 AM
> To: Zhang Yuliang
> Cc: Gofron, Kazimierz; [email protected]
> Subject: Re: Re: stream Device I/O error
> Sorry for the mistake. The protocol file should as follows:
> InTerminator =CR LF;
> get_gains{
> out "CALIB:GAI?";
> # read and redirect 9 values
> in "%d,%(\$1:Gain:1-RB)s,%(\$1:Gain:2-RB)s,%(\$1:Gain:3-RB)s",
> "%(\$1:Gain:4-RB)s,%(\$1:Gain:5-RB)s,%(\$1:Gain:6-RB)s",
> "%(\$1:Gain:7-RB)s,%(\$1:Gain:8-RB)s,%(\$1:Gain:9-RB)s";
> Regards,
> Yuliang
>> ???: "Zhang Yuliang" <[email protected]>
>> ????: 2016?4?28? ???
>> ???: "Gofron, Kazimierz" <[email protected]>
>> ??: "[email protected]" <[email protected]>
>> ??: Re: stream Device I/O error
>> Hi Kaz,
>> You can use redirection to other records to parse multiple values
from one message. Here is an example:
>> # Let this be the master record
>> record (ai, "$(DEVICE):m1)
>> field (SCAN, "1 second")
>> # pass $(DEVICE) to the protocol as parameter 1
>> field (INP, "@I404.protocol get_gains($(DEVICE)) $(PORT)") }
>> record (stringin, $(DEVICE):Gain:1-RB) {
>> # this record is passive and use Soft Channel (both default) }
>> # records Gain:2-RB...Gain:9-RB the same
>> In the protocol file I404.protocol define get_gains:
>> get_gains{
>> out "CALIB:GAI?";
>> in "%*d,%(\$1:Gain:1-RB)s,%(\$1:Gain:2-RB)s,%(\$1:Gain:3-RB)s",
>> HTH!
>> Regards,
>> Yuliang
>>> ???: "[email protected]" <[email protected]>
>>> ??: stream Device I/O error
>>> Hi,
>>> For i404 device, the gains need to be read in. There are 9 values
in the response string of which 8 last values are gains:
>>> 15,9.4377e-01,9.3736e-01,9.3128e-01,9.4361e-01,1.0179e+00,1.0184e+00
>>> ,1.0195e+00
>>> For method C, discussed here:
>>> http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html
>>> only up to 4 PVs can be read with streamDevice, otherwise "Forgot
the leading '@' or confused INP with OUT" somewhat misleading message
appears.
>>> http://www.aps.anl.gov/epics/tech-talk/2015/msg00689.php
>>> int items = sscanf(ioLink->value.instio.string, "%s%s%s%n%i%n",
>>> filename, protocol, busname, &n, addr, &n);
>>> if (items <= 0)
>>> error("%s: Empty I/O link. "
>>> "Forgot the leading '@' or confused INP with OUT ?\n",
>>> name());
>>> return S_dev_badInitRet;
>>> So this can not be done with method C .protocol file like this would
>>> not work:
>>> getKs {out "CALIB:GAI?"; in
>>> "CALIB:GAI?\10\06%*d,%e,%(\$1\$2.VAL)e,%(\$1\$3.VAL)e,%(\$1\$4.VAL)e
>>> ,%(\$1\$5.VAL)e,%(\$1\$6.VAL)e,%(\$1\$7.VAL)e,%(\$1\$8.VAL)e";
>>> InTerminator = CR LF; } ====================
>>> Using method B for reading multiple values, the protocol, and
database look as follows:
>>> getGc1 {out "CALIB:GAI?"; in
>>> "CALIB:GAI?\10\06%*d,%e,%*e,%*e,%*e,%*e,%*e,%*e,%*e"; InTerminator =
>>> CR LF; }
>>> getGc2 {in "CALIB:GAI?\10\06%*d,%*e,%e,%*e,%*e,%*e,%*e,%*e,%*e";
>>> getGc3 {in "CALIB:GAI?\10\06%*d,%*e,%*e,%e,%*e,%*e,%*e,%*e,%*e";
>>> getGc4 {in "CALIB:GAI?\10\06%*d,%*e,%*e,%*e,%e,%*e,%*e,%*e,%*e";
>>> getGc5 {in "CALIB:GAI?\10\06%*d,%*e,%*e,%*e,%*e,%e,%*e,%*e,%*e";
>>> getGc6 {in "CALIB:GAI?\10\06%*d,%*e,%*e,%*e,%*e,%*e,%e,%*e,%*e";
>>> getGc7 {in "CALIB:GAI?\10\06%*d,%*e,%*e,%*e,%*e,%*e,%*e,%e,%*e";
>>> getGc8 {in "CALIB:GAI?\10\06%*d,%*e,%*e,%*e,%*e,%*e,%*e,%*e,%e";
>>> InTerminator = CR LF; } getGst {in
>>> "CALIB:GAI?\10\06%d,%*e,%*e,%*e,%*e,%*e,%*e,%*e,%*e"; InTerminator =
>>> CR LF; } #
>>> record(ai, "$(Sys)$(Dev)Gain:1-RB") {
>>> field(DESC, "COMPENSATION FACTOR A IN")
>>> field(DTYP, "stream")
>>> field(INP, "@I404.protocol getGc1 $(PORT) 0")
>>> field(PINI, "YES")
>>> field(SCAN, "Passive")
>>> record(ai, "$(Sys)$(Dev)Gain:2-RB") {
>>> field(DESC, "COMPENSATION FACTOR B IN")
>>> field(INP, "@I404.protocol getGc2 $(PORT) 0")
>>> field(SCAN, "I/O Intr")
>>> record(ai, "$(Sys)$(Dev)Gain:3-RB") {
>>> field(DESC, "COMPENSATION FACTOR C IN")
>>> field(INP, "@I404.protocol getGc3 $(PORT) 0")
>>> record(ai, "$(Sys)$(Dev)Gain:8-RB") {
>>> field(DESC, "COMPENSATION FACTOR 3300pF D IN")
>>> field(INP, "@I404.protocol getGc8 $(PORT) 0")
>>> However, when IOC exits, a message shows:
>>> exit
>>> 2016/04/27 21:31:06.523109 COM1 XF:10IDC-BI{i404:2}Gain:2-RB:
asynError in read: 10.10.2.64:4003 disconnected:
>>> 2016/04/27 21:31:06.523155 COM1 XF:10IDC-BI{i404:2}Gain:2-RB: I/O
error after reading 0 bytes: ""
>>> 2016/04/27 21:31:06.523191 COM1 XF:10IDC-BI{i404:2}Gain:2-RB:
>>> Protocol aborted
>>> 2016/04/27 21:31:06.523220 COM1 XF:10IDC-BI{i404:2}Gain:3-RB:
>>> 2016/04/27 21:31:06.523236 COM1 XF:10IDC-BI{i404:2}Gain:3-RB: I/O
>>> 2016/04/27 21:31:06.523252 COM1 XF:10IDC-BI{i404:2}Gain:3-RB:
>>> Protocol aborted
>>> 2016/04/27 21:31:06.523268 COM1 XF:10IDC-BI{i404:2}Gain:4-RB:
>>> 2016/04/27 21:31:06.523293 COM1 XF:10IDC-BI{i404:2}Gain:4-RB: I/O
>>> 2016/04/27 21:31:06.523308 COM1 XF:10IDC-BI{i404:2}Gain:4-RB:
>>> Protocol aborted
>>> 2016/04/27 21:31:06.523333 COM1 XF:10IDC-BI{i404:2}Gain:5-RB:
>>> 2016/04/27 21:31:06.523349 COM1 XF:10IDC-BI{i404:2}Gain:5-RB: I/O
>>> 2016/04/27 21:31:06.523364 COM1 XF:10IDC-BI{i404:2}Gain:5-RB:
>>> Protocol aborted
>>> 2016/04/27 21:31:06.523379 COM1 XF:10IDC-BI{i404:2}Gain:6-RB:
>>> 2016/04/27 21:31:06.523395 COM1 XF:10IDC-BI{i404:2}Gain:6-RB: I/O
>>> 2016/04/27 21:31:06.523410 COM1 XF:10IDC-BI{i404:2}Gain:6-RB:
>>> Protocol aborted
>>> 2016/04/27 21:31:06.523425 COM1 XF:10IDC-BI{i404:2}Gain:7-RB:
>>> 2016/04/27 21:31:06.523441 COM1 XF:10IDC-BI{i404:2}Gain:7-RB: I/O
>>> 2016/04/27 21:31:06.523455 COM1 XF:10IDC-BI{i404:2}Gain:7-RB:
>>> Protocol aborted
>>> 2016/04/27 21:31:06.523471 COM1 XF:10IDC-BI{i404:2}Gain:8-RB:
>>> 2016/04/27 21:31:06.523487 COM1 XF:10IDC-BI{i404:2}Gain:8-RB: I/O
>>> 2016/04/27 21:31:06.523501 COM1 XF:10IDC-BI{i404:2}Gain:8-RB:
>>> Protocol aborted
>>> 2016/04/27 21:31:06.523518 COM1 XF:10IDC-BI{i404:2}Gain:Sts-RB:
>>> 2016/04/27 21:31:06.523533 COM1 XF:10IDC-BI{i404:2}Gain:Sts-RB: I/O
>>> 2016/04/27 21:31:06.523548 COM1 XF:10IDC-BI{i404:2}Gain:Sts-RB:
>>> Protocol aborted
>>> Not sure if anyone else sees same behavior?
>>> Kaz
