1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stream device: how to send waveform of chars without null terminator?
To: <[email protected]>
Cc: [email protected]
Date: Thu, 2 Apr 2015 15:03:46 +0200
Here is the bug fix.
Dirk
On 01.04.2015 14:03, Dirk Zimoch wrote:
On 01.04.2015 12:07, Isabella Rey wrote:
Hi Ralph,
Yes, but with %s the device receives something like:
load_curve 675892112117108115101461161201160 3870\r\n
You are right. And I think that is a bug.
Dirk
The null character corresponds to the 0 at the end of the waveform (I've
checked it with small strings)
Isabella
On 1 April 2015 at 10:44, Ralph Lange <[email protected]
<mailto:[email protected]>> wrote:
    Have you tried using "%s" for the string output?
    ~Ralph
    On 01/04/2015 10:44, Isabella Rey wrote:
        Hi All,
        I have a device to which I need to send a file path followed by
        a number:
        example:
        load_curve C:\pulse.txt 3870
        The file path is stored in the database as a waveform of chars.
        When I run the protocol stream device sends (what I think is) a
        null terminator after the file path:
        device receives:
        load_curve C:\pulse.txt\x00 3870
        Is there any way of getting rid of the \x00 terminator?
        Below I copy my protocol and the database records.
        Cheers,
        Isabella
        I've defined the protocol in stream device as:
        load_curve
             out "load_curve %(\$1)c %(\$2)i";
             in "%(\$1:\$2)b";
        and in the database I have:
        record(bo, "DEV:LOAD_CURVE") {
           field(DTYP, "stream")
           field(OUT, "@my.proto load_curve(DEV:CURVE_FILE, DEV:VPI)
        $(PORT)")
        record(waveform, "DEV:CURVE_FILE") {
           field(DESC, "File path")
           field(DTYP, "Soft Channel")
           field(NELM, "256")
           field(FTVL, "CHAR")
* StreamDevice Support                                         *
* (C) 1999 Dirk Zimoch ([email protected])          *
* (C) 2005 Dirk Zimoch ([email protected])                    *
* This is the interface to EPICS for StreamDevice.             *
* Please refer to the HTML files in ../doc/ for a detailed     *
* documentation.                                               *
* If you do any changes in this file, you are not allowed to   *
* redistribute it any more. If there is a bug or a missing     *
* feature, send me an email and/or your patch. If I accept     *
* your changes, they will go to the next release.              *
* DISCLAIMER: If this software breaks something or harms       *
* someone, it's your problem.                                  *
#define epicsExportSharedSymbols
#include "devStream.h"
#undef epicsExportSharedSymbols
#include "StreamCore.h"
#include "StreamError.h"
#include <epicsVersion.h>
#ifdef BASE_VERSION
#define EPICS_3_13
#endif
#ifdef EPICS_3_13
extern "C" {
#endif
#define epicsAlarmGLOBAL
#include <alarm.h>
#undef epicsAlarmGLOBAL
#include <ctype.h>
#include <stdarg.h>
#include <stdlib.h>
#include <dbStaticLib.h>
#include <drvSup.h>
#include <recSup.h>
#include <recGbl.h>
#include <devLib.h>
#include <callback.h>
#ifdef EPICS_3_13
#include <semLib.h>
#include <wdLib.h>
#include <taskLib.h>
extern DBBASE *pdbbase;
} // extern "C"
#else
#include <epicsTimer.h>
#include <epicsMutex.h>
#include <epicsEvent.h>
#include <epicsTime.h>
#include <epicsThread.h>
#include <registryFunction.h>
#include <iocsh.h>
#if EPICS_MODIFICATION<9
extern "C" {
// iocshCmd() is missing in iocsh.h (up to R3.14.8.2)
// To build with win32-x86, you MUST fix iocsh.h.
// Move the declaration below to iocsh.h and rebuild base.
epicsShareFunc int epicsShareAPI iocshCmd(const char *command);
#endif
#include <epicsExport.h>
#endif
#if defined(__vxworks) || defined(vxWorks)
#include <symLib.h>
#include <sysSymTbl.h>
#endif
enum MoreFlags {
    // 0x00FFFFFF used by StreamCore
    InDestructor  = 0x0100000,
    ValueReceived = 0x0200000,
    Aborted       = 0x0400000
extern "C" void streamExecuteCommand(CALLBACK *pcallback);
extern "C" void streamRecordProcessCallback(CALLBACK *pcallback);
extern "C" long streamReload(char* recordname);
class Stream : protected StreamCore
#ifndef EPICS_3_13
    , epicsTimerNotify
#endif
    dbCommon* record;
    const struct link *ioLink;
    streamIoFunction readData;
    streamIoFunction writeData;
#ifdef EPICS_3_13
    WDOG_ID timer;
    CALLBACK timeoutCallback;
    SEM_ID mutex;
    SEM_ID initDone;
#else
    epicsTimerQueueActive* timerQueue;
    epicsTimer* timer;
    epicsMutex mutex;
    epicsEvent initDone;
#endif
    StreamBuffer fieldBuffer;
    int status;
    int convert;
    long currentValueLength;
    IOSCANPVT ioscanpvt;
    CALLBACK commandCallback;
    CALLBACK processCallback;
#ifdef EPICS_3_13
    static void expire(CALLBACK *pcallback);
#else
// epicsTimerNotify method
    expireStatus expire(const epicsTime&);
#endif
// StreamCore methods
    void protocolStartHook();
    void protocolFinishHook(ProtocolResult);
    void startTimer(unsigned long timeout);
    bool getFieldAddress(const char* fieldname,
        StreamBuffer& address);
    bool formatValue(const StreamFormat&,
        const void* fieldaddress);
    bool matchValue(const StreamFormat&,
    void lockMutex();
    void releaseMutex();
    bool execute();
    friend void streamExecuteCommand(CALLBACK *pcallback);
    friend void streamRecordProcessCallback(CALLBACK *pcallback);
// Stream Epics methods
    Stream(dbCommon* record, const struct link *ioLink,
        streamIoFunction readData, streamIoFunction writeData);
    ~Stream();
    long parseLink(const struct link *ioLink, char* filename, char* protocol,
        char* busname, int* addr, char* busparam);
    long initRecord(const char* filename, const char* protocol,
        const char* busname, int addr, const char* busparam);
    bool print(format_t *format, va_list ap);
    bool scan(format_t *format, void* pvalue, size_t maxStringSize);
    bool process();
// device support functions
    friend long streamInitRecord(dbCommon *record, const struct link *ioLink,
    friend long streamReadWrite(dbCommon *record);
    friend long streamGetIointInfo(int cmd, dbCommon *record,
        IOSCANPVT *ppvt);
    friend long streamPrintf(dbCommon *record, format_t *format, ...);
    friend long streamScanfN(dbCommon *record, format_t *format,
        void*, size_t maxStringSize);
    friend long streamReload(char* recordname);
public:
    long priority() { return record->prio; };
    static long report(int interest);
    static long drvInit();
// shell functions ///////////////////////////////////////////////////////
#ifndef EPICS_3_13
extern "C" {
epicsExportAddress(int, streamDebug);
#endif
// for subroutine record
extern "C" long streamReloadSub()
    return streamReload(NULL);
    DBENTRY	dbentry;
    dbCommon*   record;
    long status;
    if(!pdbbase) {
        error("No database has been loaded\n");
        return ERROR;
    debug("streamReload(%s)\n", recordname);
    dbInitEntry(pdbbase,&dbentry);
    for (status = dbFirstRecordType(&dbentry); status == OK;
        status = dbNextRecordType(&dbentry))
        for (status = dbFirstRecord(&dbentry); status == OK;
            status = dbNextRecord(&dbentry))
            char* value;
            if (dbFindField(&dbentry, "DTYP") != OK)
                continue;
            if ((value = dbGetString(&dbentry)) == NULL)
                continue;
            if (strcmp(value, "stream") != 0)
                continue;
            record=(dbCommon*)dbentry.precnode->precord;
            if (recordname && strcmp(recordname, record->name) != 0)
                continue;
            // This cancels any running protocol and reloads
            // the protocol file
            status = record->dset->init_record(record);
            if (status == OK || status == DO_NOT_CONVERT)
                printf("%s: Protocol reloaded\n", record->name);
            else
                error("%s: Protocol reload failed\n", record->name);
    dbFinishEntry(&dbentry);
    StreamProtocolParser::free();
    return OK;
#ifndef EPICS_3_13
static const iocshArg streamReloadArg0 =
    { "recordname", iocshArgString };
static const iocshArg * const streamReloadArgs[] =
    { &streamReloadArg0 };
static const iocshFuncDef reloadDef =
    { "streamReload", 1, streamReloadArgs };
extern "C" void streamReloadFunc (const iocshArgBuf *args)
    streamReload(args[0].sval);
static void streamRegistrar ()
    iocshRegister(&reloadDef, streamReloadFunc);
    // make streamReload available for subroutine records
    registryFunctionAdd("streamReload",
        (REGISTRYFUNCTION)streamReloadSub);
    registryFunctionAdd("streamReloadSub",
extern "C" {
epicsExportRegistrar(streamRegistrar);
#endif
// driver support ////////////////////////////////////////////////////////
struct stream_drvsup {
    long number;
    long (*report)(int);
    long (*init)();
} stream = {
    2,
    Stream::report,
    Stream::drvInit
#ifndef EPICS_3_13
extern "C" {
epicsExportAddress(drvet, stream);
#endif
#ifdef EPICS_3_13
void streamEpicsPrintTimestamp(char* buffer, int size)
    int tlen;
    char* c;
    TS_STAMP tm;
    tsLocalTime (&tm);
    tsStampToText(&tm, TS_TEXT_MMDDYY, buffer);
    c = strchr(buffer,'.');
    if (c) {
        c[4] = 0;
    tlen = strlen(buffer);
    sprintf(buffer+tlen, " %.*s", size-tlen-2, taskName(0));
#else
    int tlen;
    epicsTime tm = epicsTime::getCurrent();
    tlen = tm.strftime(buffer, size, "%Y/%m/%d %H:%M:%S.%06f");
    sprintf(buffer+tlen, " %.*s", size-tlen-2, epicsThreadGetNameSelf());
#endif
long Stream::
    debug("Stream::report(interest=%d)\n", interest);
    printf("  %s\n", StreamVersion);
    printf("  registered bus interfaces:\n");
    StreamBusInterfaceClass interface;
    while (interface)
        printf("    %s\n", interface.name());
        ++interface;
    if (interest < 1) return OK;
    printf("  registered converters:\n");
    StreamFormatConverter* converter;
    int c;
    for (c=0; c < 256; c++)
        converter = StreamFormatConverter::find(c);
        if (converter)
            printf("    %%%c %s\n", c, converter->name());
    Stream* pstream;
    printf("  connected records:\n");
    for (pstream = static_cast<Stream*>(first); pstream;
        pstream = static_cast<Stream*>(pstream->next))
        if (interest == 2)
            printf("\n%s: %s\n", pstream->name(),
                pstream->ioLink->value.instio.string);
            pstream->printProtocol();
        else
            printf("    %s: %s\n", pstream->name(),
            if (interest == 3)
                StreamBuffer buffer;
                pstream->printStatus(buffer);
                printf("      %s\n", buffer());
    return OK;
long Stream::
drvInit()
    char* path;
    debug("drvStreamInit()\n");
    path = getenv("STREAM_PROTOCOL_PATH");
    // for compatibility reasons look for global symbols
    if (!path)
        char* symbol;
        SYM_TYPE type;
        if (symFindByName(sysSymTbl,
            "STREAM_PROTOCOL_PATH", &symbol, &type) == OK)
            path = *(char**)symbol;
        else
            "STREAM_PROTOCOL_DIR", &symbol, &type) == OK)
#endif
    if (!path)
        fprintf(stderr,
            "drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. "
            "Defaults to \"%s\"\n", StreamProtocolParser::path);
    else
        StreamProtocolParser::path = path;
    debug("StreamProtocolParser::path = %s\n",
    StreamPrintTimestampFunction = streamEpicsPrintTimestamp;
    return OK;
// device support (C interface) //////////////////////////////////////////
long streamInit(int after)
    if (after)
    return OK;
long streamInitRecord(dbCommon* record, const struct link *ioLink,
    long status;
    char filename[80];
    char protocol[80];
    char busname[80];
    int addr = -1;
    char busparam[80];
    memset(busparam, 0 ,sizeof(busparam));
    debug("streamInitRecord(%s): SEVR=%d\n", record->name, record->sevr);
    Stream* pstream = (Stream*)record->dpvt;
    if (!pstream)
        // initialize the first time
        debug("streamInitRecord(%s): create new Stream object\n",
            record->name);
        pstream = new Stream(record, ioLink, readData, writeData);
        record->dpvt = pstream;
    } else {
        // stop any running protocol
        debug("streamInitRecord(%s): stop running protocol\n",
            record->name);
        pstream->finishProtocol(Stream::Abort);
    // scan the i/o link
    debug("streamInitRecord(%s): parse link \"%s\"\n",
        record->name, ioLink->value.instio.string);
    status = pstream->parseLink(ioLink, filename, protocol,
        busname, &addr, busparam);
    // (re)initialize bus and protocol
    debug("streamInitRecord(%s): calling initRecord\n",
        record->name);
    if (status == 0)
        status = pstream->initRecord(filename, protocol,
            busname, addr, busparam);
    if (status != OK && status != DO_NOT_CONVERT)
        error("%s: Record initialization failed\n", record->name);
    else if (!pstream->ioscanpvt)
        scanIoInit(&pstream->ioscanpvt);
    debug("streamInitRecord(%s) done status=%#lx\n", record->name, status);
    return status;
    if (!pstream || pstream->status == ERROR)
        (void) recGblSetSevr(record, UDF_ALARM, INVALID_ALARM);
        error("%s: Record not initialised correctly\n", record->name);
        return ERROR;
    return pstream->process() ? pstream->convert : ERROR;
long streamGetIointInfo(int cmd, dbCommon *record, IOSCANPVT *ppvt)
    debug("streamGetIointInfo(%s,cmd=%d): pstream=%p, ioscanpvt=%p\n",
        record->name, cmd,
        (void*)pstream, pstream ? pstream->ioscanpvt : NULL);
    if (!pstream)
        error("streamGetIointInfo called without stream instance\n");
        return ERROR;
    *ppvt = pstream->ioscanpvt;
    if (cmd == 0)
        debug("streamGetIointInfo: starting protocol\n");
        // SCAN has been set to "I/O Intr"
        if (!pstream->startProtocol(Stream::StartAsync))
            error("%s: Can't start \"I/O Intr\" protocol\n",
                record->name);
    else
        // SCAN is no longer "I/O Intr"
    return OK;
    debug("streamPrintf(%s,format=%%%c)\n",
        record->name, format->priv->conv);
    if (!pstream) return ERROR;
    va_list ap;
    va_start(ap, format);
    bool success = pstream->print(format, ap);
    va_end(ap);
    return success ? OK : ERROR;
long streamScanfN(dbCommon* record, format_t *format,
    void* value, size_t maxStringSize)
    debug("streamScanfN(%s,format=%%%c,maxStringSize=%ld)\n",
        record->name, format->priv->conv, (long)maxStringSize);
    if (!pstream->scan(format, value, maxStringSize))
        return ERROR;
#ifndef NO_TEMPORARY
    debug("streamScanfN(%s) success, value=\"%s\"\n",
        record->name, StreamBuffer((char*)value).expand()());
#endif
    return OK;
// Stream methods ////////////////////////////////////////////////////////
Stream::
Stream(dbCommon* _record, const struct link *ioLink,
:record(_record), ioLink(ioLink), readData(readData), writeData(writeData)
    streamname = record->name;
#ifdef EPICS_3_13
    timer = wdCreate();
    mutex = semMCreate(SEM_INVERSION_SAFE | SEM_Q_PRIORITY);
    initDone = semBCreate(SEM_Q_FIFO, SEM_EMPTY);
    callbackSetCallback(expire, &timeoutCallback);
    callbackSetUser(this, &timeoutCallback);
#else
    timerQueue = &epicsTimerQueueActive::allocate(true);
    timer = &timerQueue->createTimer();
#endif
    callbackSetCallback(streamExecuteCommand, &commandCallback);
    callbackSetUser(this, &commandCallback);
    callbackSetCallback(streamRecordProcessCallback, &processCallback);
    callbackSetUser(this, &processCallback);
    status = ERROR;
    convert = DO_NOT_CONVERT;
    ioscanpvt = NULL;
Stream::
~Stream()
    lockMutex();
    flags |= InDestructor;;
    debug("~Stream(%s) %p\n", name(), (void*)this);
    if (record->dpvt)
        finishProtocol(Abort);
        debug("~Stream(%s): protocol finished\n", name());
        record->dpvt = NULL;
        debug("~Stream(%s): dpvt cleared\n", name());
#ifdef EPICS_3_13
    wdDelete(timer);
    debug("~Stream(%s): watchdog destroyed\n", name());
#else
    timer->destroy();
    debug("~Stream(%s): timer destroyed\n", name());
    timerQueue->release();
    debug("~Stream(%s): timer queue released\n", name());
#endif
    releaseMutex();
long Stream::
    char* protocol, char* busname, int* addr, char* busparam)
    // parse link parameters: filename protocol busname addr busparam
    int n;
    if (ioLink->type != INST_IO)
        error("%s: Wrong I/O link type %s\n", name(),
            pamaplinkType[ioLink->type].strvalue);
        return S_dev_badInitRet;
    int items = sscanf(ioLink->value.instio.string, "%s%s%s%n%i%n",
        filename, protocol, busname, &n, addr, &n);
    if (items <= 0)
        error("%s: Empty I/O link. "
            "Forgot the leading '@' or confused INP with OUT ?\n",
            name());
    if (items < 3)
        error("%s: Wrong I/O link format\n"
            "  expect \"@file protocol bus addr params\"\n"
            "  in \"@%s\"\n", name(),
    while (isspace((unsigned char)ioLink->value.instio.string[n])) n++;
    strcpy (busparam, ioLink->value.constantStr+n);
    return OK;
long Stream::
    // It is safe to call this function again with different arguments
    // attach to bus interface
    debug("Stream::initRecord %s: attachBus(%s, %d, \"%s\")\n",
        name(), busname, addr, busparam);
    if (!attachBus(busname, addr, busparam))
        error("%s: Can't attach to bus %s %d\n",
            name(), busname, addr);
        return S_dev_noDevice;
    // parse protocol file
    debug("Stream::initRecord %s: parse(%s, %s)\n",
        name(), filename, protocol);
    if (!parse(filename, protocol))
        error("%s: Protocol parse error\n",
            name());
    // record is ready to use
    status = NO_ALARM;
    if (ioscanpvt)
        // we have been called by streamReload
        debug("Stream::initRecord %s: initialize after streamReload\n",
            name());
        if (record->scan == SCAN_IO_EVENT)
            debug("Stream::initRecord %s: "
                "restarting \"I/O Intr\" after reload\n",
                name());
            if (!startProtocol(StartAsync))
                error("%s: Can't restart \"I/O Intr\" protocol\n",
                    name());
        return OK;
    debug("Stream::initRecord %s: initialize the first time\n",
        name());
    if (!onInit) return DO_NOT_CONVERT; // no @init handler, keep DOL
    // initialize the record from hardware
    if (!startProtocol(StartInit))
        error("%s: Can't start init run\n",
            name());
        return ERROR;
    debug("Stream::initRecord %s: waiting for initDone\n",
        name());
#ifdef EPICS_3_13
    semTake(initDone, WAIT_FOREVER);
#else
    initDone.wait();
#endif
    debug("Stream::initRecord %s: initDone\n",
        name());
    // init run has set status and convert
    if (status != NO_ALARM)
        record->stat = status;
        error("%s: @init handler failed\n",
            name());
        return ERROR;
    debug("Stream::initRecord %s: initialized. convert=%d\n",
        name(), convert);
    return convert;
bool Stream::
process()
    MutexLock lock(this);
    if (record->pact || record->scan == SCAN_IO_EVENT)
            debug("Stream::process(%s) error status=%s (%d)\n",
                name(),
                status >= 0 && status < ALARM_NSTATUS ?
                    epicsAlarmConditionStrings[status] : "ERROR",
                status);
            (void) recGblSetSevr(record, status, INVALID_ALARM);
            return false;
        debug("Stream::process(%s) ready. %s\n",
            name(), convert==2 ?
            "convert" : "don't convert");
        return true;
    if (flags & InDestructor)
        error("%s: Try to process while in stream destructor (try later)\n",
            name());
        return false;
    debug("Stream::process(%s) start\n", name());
    status = NO_ALARM;
    convert = OK;
    record->pact = true;
    if (!startProtocol(StreamCore::StartNormal))
        debug("Stream::process(%s): could not start, status=%d\n",
            name(), status);
        record->pact = false;
        return false;
    debug("Stream::process(%s): protocol started\n", name());
    return true;
bool Stream::
    long lval;
    double dval;
    char* sval;
    switch (format->type)
        case DBF_ENUM:
        case DBF_LONG:
            lval = va_arg(ap, long);
            return printValue(*format->priv, lval);
        case DBF_DOUBLE:
            dval = va_arg(ap, double);
            return printValue(*format->priv, dval);
        case DBF_STRING:
            sval = va_arg(ap, char*);
            return printValue(*format->priv, sval);
    error("INTERNAL ERROR (%s): Illegal format type\n", name());
    return false;
bool Stream::
scan(format_t *format, void* value, size_t maxStringSize)
    // called by streamScanfN
    long* lptr;
    double* dptr;
    char* sptr;
    // first remove old value from inputLine (if we are scanning arrays)
    consumedInput += currentValueLength;
    currentValueLength = 0;
        case DBF_LONG:
        case DBF_ENUM:
            lptr = (long*)value;
            currentValueLength = scanValue(*format->priv, *lptr);
            break;
        case DBF_DOUBLE:
            dptr = (double*)value;
            currentValueLength = scanValue(*format->priv, *dptr);
            break;
        case DBF_STRING:
            sptr = (char*)value;
            currentValueLength  = scanValue(*format->priv, sptr,
                maxStringSize);
            break;
        default:
            return false;
    if (currentValueLength < 0)
        return false;
    // Don't remove scanned value from inputLine yet, because
    // we might need the string in a later error message.
    return true;
// epicsTimerNotify virtual method ///////////////////////////////////////
#ifdef EPICS_3_13
void Stream::
    Stream* pstream = static_cast<Stream*>(pcallback->user);
    pstream->timerCallback();
#else
epicsTimerNotify::expireStatus Stream::
    timerCallback();
    return noRestart;
#endif
// StreamCore virtual methods ////////////////////////////////////////////
void Stream::
protocolStartHook()
    flags &= ~Aborted;
void Stream::
protocolFinishHook(ProtocolResult result)
    switch (result)
        case Success:
            status = NO_ALARM;
            if (flags & ValueReceived)
                record->udf = false;
                if (flags & InitRun)
                    // records start with UDF/INVALID,
                    // but now this record has a value
                    record->sevr = NO_ALARM;
                    record->stat = NO_ALARM;
            break;
        case LockTimeout:
        case ReplyTimeout:
            status = TIMEOUT_ALARM;
            break;
        case WriteTimeout:
            status = WRITE_ALARM;
            break;
        case ReadTimeout:
            status = READ_ALARM;
            break;
        case ScanError:
        case FormatError:
            status = CALC_ALARM;
            break;
        case Abort:
            flags |= Aborted;
        case Fault:
            status = UDF_ALARM;
                error("%s: Protocol aborted\n", name());
            break;
        default:
            status = UDF_ALARM;
            error("INTERNAL ERROR (%s): Illegal protocol result\n",
                name());
            break;
#ifdef EPICS_3_13
        semGive(initDone);
#else
        initDone.signal();
#endif
        return;
    if (result != Abort && record->scan == SCAN_IO_EVENT)
        // re-enable early input
        flags |= AcceptInput;
        // process record in callback thread to break possible recursion
        callbackSetPriority(priority(), &processCallback);
        callbackRequest(&processCallback);
    dbCommon* record = pstream->record;
    // process record
    // This will call streamReadWrite.
    debug("streamRecordProcessCallback(%s) processing record\n",
            pstream->name());
    dbScanLock(record);
    ((DEVSUPFUN)record->rset->process)(record);
    dbScanUnlock(record);
    debug("streamRecordProcessCallback(%s) processing record done\n",
            pstream->name());
    if (record->scan == SCAN_IO_EVENT && !(pstream->flags & Aborted))
        // restart protocol for next turn
        debug("streamRecordProcessCallback(%s) restart async protocol\n",
            pstream->name());
                pstream->name());
void Stream::
    debug("Stream::startTimer(stream=%s, timeout=%lu) = %f seconds\n",
        name(), timeout, timeout * 0.001);
#ifdef EPICS_3_13
    callbackSetPriority(priority(), &timeoutCallback);
    wdStart(timer, (timeout+1)*sysClkRateGet()/1000-1,
        reinterpret_cast<FUNCPTR>(callbackRequest),
        reinterpret_cast<int>(&timeoutCallback));
#else
    timer->start(*this, timeout * 0.001);
#endif
bool Stream::
getFieldAddress(const char* fieldname, StreamBuffer& address)
    DBADDR dbaddr;
    if (strchr(fieldname, '.') != NULL)
        // record.FIELD (access to other record)
        if (dbNameToAddr(fieldname, &dbaddr) != OK) return false;
    else
        // FIELD in this record or VAL in other record
        char fullname[PVNAME_SZ + 1];
        sprintf(fullname, "%s.%s", name(), fieldname);
        if (dbNameToAddr(fullname, &dbaddr) != OK)
            // VAL in other record
            sprintf(fullname, "%s.VAL", fieldname);
            if (dbNameToAddr(fullname, &dbaddr) != OK) return false;
    address.append(&dbaddr, sizeof(dbaddr));
    return true;
static const unsigned char dbfMapping[] =
    {0, DBF_LONG, DBF_ENUM, DBF_DOUBLE, DBF_STRING};
static const short typeSize[] =
    {0, sizeof(epicsInt32), sizeof(epicsUInt16),
        sizeof(epicsFloat64), MAX_STRING_SIZE};
bool Stream::
formatValue(const StreamFormat& format, const void* fieldaddress)
    debug("Stream::formatValue(%s, format=%%%c, fieldaddr=%p\n",
        name(), format.conv, fieldaddress);
// --  TO DO: If SCAN is "I/O Intr" and record has not been processed,  --
// --  do it now to get the latest value (only for output records?)     --
    if (fieldaddress)
        // Format like "%([record.]field)..." has requested to get value
        // from field of this or other record.
        DBADDR* pdbaddr = (DBADDR*)fieldaddress;
        /* Handle time stamps special. %T converter takes double. */
        if (strcmp(((dbFldDes*)pdbaddr->pfldDes)->name, "TIME") == 0)
            double time;
            if (format.type != double_format)
                error ("%s: can only read double values from TIME field\n",
                    name());
                return false;
            if (pdbaddr->precord == record)
                /* if getting time from own record, update timestamp first */
                recGblGetTimeStamp(record);
            /* convert EPICS epoch (1990) to unix epoch (1970) */
            /* we are losing about 3 digits precision here */
            time = pdbaddr->precord->time.secPastEpoch +
                631152000u + pdbaddr->precord->time.nsec * 1e-9;
            debug("Stream::formatValue(%s): read %f from TIME field\n",
                name(), time);
            return printValue(format, time);
        /* convert type to LONG, ENUM, DOUBLE, or STRING */
        int type = dbfMapping[format.type];
        long nelem = pdbaddr->no_elements;
        size_t size = nelem * typeSize[format.type];
        /* print (U)CHAR arrays as string */
        if (format.type == string_format &&
            (pdbaddr->field_type == DBF_CHAR || pdbaddr->field_type == DBF_UCHAR))
            debug("Stream::formatValue(%s): format %s.%s array[%ld] size %d of %s as string\n",
                name(),
                pdbaddr->precord->name,
                nelem,
                pdbaddr->field_size,
                pamapdbfType[pdbaddr->field_type].strvalue);
            type = DBF_CHAR;
            size = nelem;
        char* buffer = fieldBuffer.clear().reserve(size);
        if (dbGet(pdbaddr, type, buffer,
            NULL, &nelem, NULL) != 0)
            error("%s: dbGet(%s.%s, %s) failed\n",
                name(),
                pamapdbfType[dbfMapping[format.type]].strvalue);
            return false;
        debug("Stream::formatValue(%s): got %ld elements\n",
                name(),nelem);
        /* terminate CHAR array as string */
        if (type == DBF_CHAR)
            if (nelem >= pdbaddr->no_elements) nelem = pdbaddr->no_elements-1;
            buffer[nelem] = 0;
            nelem = 1; /* array is only 1 string */
        long i;
        for (i = 0; i < nelem; i++)
            switch (format.type)
                case enum_format:
                    if (!printValue(format,
                        (long)((epicsUInt16*)buffer)[i]))
                        return false;
                    break;
                case long_format:
                        (long)((epicsInt32*)buffer)[i]))
                        return false;
                    break;
                case double_format:
                        (double)((epicsFloat64*)buffer)[i]))
                        return false;
                    break;
                case string_format:
                    if (!printValue(format, buffer+MAX_STRING_SIZE*i))
                        return false;
                    break;
                case pseudo_format:
                    error("%s: %%(FIELD) syntax not allowed "
                        "with pseudo formats\n",
                        name());
                    return false;
                default:
                    error("INTERNAL ERROR %s: Illegal format.type=%d\n",
                        name(), format.type);
                    return false;
        return true;
    format_s fmt;
    fmt.type = dbfMapping[format.type];
    fmt.priv = &format;
    debug("Stream::formatValue(%s) format=%%%c type=%s\n",
        name(), format.conv, pamapdbfType[fmt.type].strvalue);
    if (!writeData)
        error("%s: No writeData() function provided\n", name());
        return false;
    if (writeData(record, &fmt) == ERROR)
        debug("Stream::formatValue(%s): writeData failed\n", name());
        return false;
    return true;
bool Stream::
matchValue(const StreamFormat& format, const void* fieldaddress)
    // this function must increase consumedInput
    long consumed;
    long lval;
    double dval;
    char* buffer;
    int status;
    const char* putfunc;
    if (fieldaddress)
        // Format like "%([record.]field)..." has requested to put value
        // to field of this or other record.
        long nord;
        for (nord = 0; nord < nelem; nord++)
            debug("Stream::matchValue(%s): buffer before: %s\n",
                name(), fieldBuffer.expand()());
                case long_format:
                    consumed = scanValue(format, lval);
                    if (consumed >= 0) ((epicsInt32*)buffer)[nord] = lval;
                    debug("Stream::matchValue(%s): %s[%li] = %li\n",
                            name(), pdbaddr->precord->name, nord, lval);
                    break;
                case enum_format:
                    if (consumed >= 0)
                        ((epicsUInt16*)buffer)[nord] = (epicsUInt16)lval;
                    break;
                case double_format:
                    consumed = scanValue(format, dval);
                    // Direct assignment to buffer fails with
                    // gcc 3.4.3 for xscale_be
                    // Optimization bug?
                    epicsFloat64 f64=dval;
                    if (consumed >= 0)
                        memcpy(((epicsFloat64*)buffer)+nord,
                            &f64, sizeof(f64));
                    debug("Stream::matchValue(%s): %s[%li] = %#g %#g\n",
                            name(), pdbaddr->precord->name, nord, dval,
                            ((epicsFloat64*)buffer)[nord]);
                    break;
                case string_format:
                        buffer+MAX_STRING_SIZE*nord, MAX_STRING_SIZE);
                    debug("Stream::matchValue(%s): %s[%li] = \"%.*s\"\n",
                            MAX_STRING_SIZE, buffer+MAX_STRING_SIZE*nord);
                    break;
                default:
                    error("INTERNAL ERROR: Stream::matchValue %s: "
                        "Illegal format type\n", name());
                    return false;
            debug("Stream::matchValue(%s): buffer after: %s\n",
            if (consumed < 0) break;
            consumedInput += consumed;
        if (!nord)
            // scan error: set other record to alarm status
            if (pdbaddr->precord != record)
                (void) recGblSetSevr(pdbaddr->precord,
                    CALC_ALARM, INVALID_ALARM);
                if (!INIT_RUN)
                    // process other record to send alarm monitor
                    dbProcess(pdbaddr->precord);
            return false;
#ifdef epicsTimeEventDeviceTime
                error ("%s: can only write double values to TIME field\n",
                    name());
                return false;
            dval = dval-631152000u;
            pdbaddr->precord->time.secPastEpoch = (long)dval;
            // rouding: we don't have 9 digits precision
            // in a double of today's number of seconds
            pdbaddr->precord->time.nsec = (long)((dval-(long)dval)*1e6)*1000;
            debug("Stream::matchValue(%s): writing %i.%i to TIME field\n",
                name(),
                pdbaddr->precord->time.secPastEpoch,
                pdbaddr->precord->time.nsec);
            pdbaddr->precord->tse = epicsTimeEventDeviceTime;
            return true;
#else
            error ("%s: writing TIME field is not supported "
                "in this EPICS version\n", name());
            return false;
#endif
        if (pdbaddr->precord == record || INIT_RUN)
            // write into own record, thus don't process it
            // in @init we must not process other record
            debug("Stream::matchValue(%s): dbPut(%s.%s,%s)\n",
                name(),
            putfunc = "dbPut";
            status = dbPut(pdbaddr, dbfMapping[format.type], buffer, nord);
            if (INIT_RUN && pdbaddr->precord != record)
                // clean error status of other record in @init
                pdbaddr->precord->udf = false;
                pdbaddr->precord->sevr = NO_ALARM;
                pdbaddr->precord->stat = NO_ALARM;
        else
            // write into other record, thus process it
            debug("Stream::matchValue(%s): dbPutField(%s.%s,%s)\n",
                name(),
            putfunc = "dbPutField";
            status = dbPutField(pdbaddr, dbfMapping[format.type],
                buffer, nord);
        if (status != 0)
            flags &= ~ScanTried;
                case long_format:
                case enum_format:
                    error("%s: %s(%s.%s, %s, %li) failed\n",
                        putfunc, name(), pdbaddr->precord->name,
                        pamapdbfType[dbfMapping[format.type]].strvalue,
                        lval);
                    return false;
                case double_format:
                    error("%s: %s(%s.%s, %s, %#g) failed\n",
                        dval);
                    return false;
                case string_format:
                    error("%s: %s(%s.%s, %s, \"%s\") failed\n",
                        buffer);
                    return false;
                default:
                    return false;
        return true;
    // no fieldaddress (the "normal" case)
    format_s fmt;
    fmt.priv = &format;
    if (!readData)
        error("%s: No readData() function provided\n", name());
        return false;
    convert = readData(record, &fmt); // this will call scan()
    if (convert == ERROR)
        debug("Stream::matchValue(%s): readData failed\n", name());
        if (currentValueLength > 0)
            error("%s: Record does not accept input \"%s%s\"\n",
                name(), inputLine.expand(consumedInput, 19)(),
                inputLine.length()-consumedInput > 20 ? "..." : "");
        return false;
    flags |= ValueReceived;
    return true;
#ifdef EPICS_3_13
// Pass command to vxWorks shell
extern "C" int execute(const char *cmd);
    if (execute(pstream->outputLine()) != OK)
        pstream->execCallback(StreamIoFault);
    else
        pstream->execCallback(StreamIoSuccess);
#else
// Pass command to iocsh
    if (iocshCmd(pstream->outputLine()) != OK)
    else
#endif
bool Stream::
execute()
    callbackSetPriority(priority(), &commandCallback);
    callbackRequest(&commandCallback);
    return true;
void Stream::
lockMutex()
#ifdef EPICS_3_13
    semTake(mutex, WAIT_FOREVER);
#else
    mutex.lock();
#endif
void Stream::
releaseMutex()
#ifdef EPICS_3_13
    semGive(mutex);
#else
    mutex.unlock();
#endif
Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
Re: Stream device: how to send waveform of chars without null terminator? Ralph Lange
Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Prev: RE: data of modbus write function didn't updated automatically Mark Rivers
Next: Remember to Register for the Spring 2015 EPICS Collaboration Meeting Spring 2015 EPICS Collaboration Meeting
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Next: Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
