1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: mrfioc2 loading error at vxWorks 6.9
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 6 Jan 2016 06:27:19 +0000
Hi  Michael, Eric and Martin,
I has been reinstalled devlib2 module from the "https://github.com/epicsdeb/devlib2/pull/12";.
And rebuild devlib2 and mrfioc2 modules but seems same result.
-> ld < mrf.munch
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z13sysPciOutLongPjj.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z13sysPciOutWordPtt.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z12sysPciInWordPt.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z12sysPciInLongPj.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z12sysPciInBytePh.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z13sysPciOutBytePhh.
ld(): module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
-> lkup sysPciOutLong
value = 0 = 0x0
-> lkup sysPciOutWord
value = 0 = 0x0
-> lkup sysPciInWord
value = 0 = 0x0
Here is my target file info.
[root@localhost mv6100]#  grep 'define BSP_' config.h
#define BSP_VERSION        "6.9"       /* vxWorks 6.9 */
#define BSP_REV            "/0"        /* 0 for first revision */
[root@localhost mv6100]# grep sysPci sysAUtil.s
    FUNC_EXPORT(sysPciInByte)
    FUNC_EXPORT(sysPciOutByte)
    FUNC_EXPORT(sysPciInWord)
    FUNC_EXPORT(sysPciOutWord)
    FUNC_EXPORT(sysPciInLong)
    FUNC_EXPORT(sysPciOutLong)
* sysPciInByte - reads a byte from PCI Config Space.
FUNC_BEGIN(sysPciInByte)
FUNC_END(sysPciInByte)
* sysPciInWord - reads a word (16-bit big-endian) from PCI Config Space.
FUNC_BEGIN(sysPciInWord)
FUNC_END(sysPciInWord)
* sysPciInLong - reads a long (32-bit big-endian) from PCI Config Space.
FUNC_BEGIN(sysPciInLong)
FUNC_END(sysPciInLong)
* sysPciOutByte - writes a byte to PCI Config Space.
FUNC_BEGIN(sysPciOutByte)
FUNC_END(sysPciOutByte)
* sysPciOutWord - writes a word (16-bit big-endian) to PCI Config Space.
FUNC_BEGIN(sysPciOutWord)
FUNC_END(sysPciOutWord)
* sysPciOutLong - writes a long (32-bit big-endian) to PCI Config Space.
FUNC_BEGIN(sysPciOutLong)
FUNC_END(sysPciOutLong)
-Ji-Hwa
보낸 사람: [email protected] <[email protected]> 대신 Michael Davidsaver <[email protected]>
보낸 날짜: 2016년 1월 6일 수요일 오전 11:07
받는 사람: [email protected]
제목: Re: mrfioc2 loading error at vxWorks 6.9
FYI this also effects EPICS Base as the MMIO headers from devlib2 are
included in >= 3.15.0.2.
https://bugs.launchpad.net/epics-base/+bug/1531359
On 01/05/2016 08:15 PM, Konrad, Martin wrote:
> Hi all,
> Eric, thanks for sharing your patch. I created a pull request [1]. After
> a quick review by Michael you can expect to see the fix in the mainline
> soon.
> Thanks,
> Martin
> [1] https://github.com/epicsdeb/devlib2/pull/12
Re: mrfioc2 loading error at vxWorks 6.9 Dirk Zimoch
Re: mrfioc2 loading error at vxWorks 6.9 Konrad, Martin
RE: mrfioc2 loading error at vxWorks 6.9 김지화(빔라인장치팀)
Re: mrfioc2 loading error at vxWorks 6.9 Andrew Johnson
Re: mrfioc2 loading error at vxWorks 6.9 Michael Davidsaver
Prev: Re: mrfioc2 loading error at vxWorks 6.9 Michael Davidsaver
Next: Re: mrfioc2 loading error at vxWorks 6.9 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
