I did the experiment Mark suggested and found that drvModbusAsyn.c is working as
expected - it returns small negative integers when small negative voltages are applied to the converter. BUT in those cases RVAL is still reported as a large positive integer. Details follow:
On Sat, 12 Dec 2015, Mark Rivers wrote:
You could add the following printf statement to drvModbusAsyn.c::readPlcInt and see what the output is for that value.
case dataTypeInt16:
result = (epicsInt16)value;
printf("readPlcInt, offset=%d, value=0x%x, result=%d (0x%x)\n", offset, value, result, result);
break;
I did that and got these results. When Vin is a small positive value +0.002 V,
value is a small positive integer and RVAL is a small positive integer:
readPlcInt, offset=0, value=0x1, result=1 (0x1)
dbgf Iso:GantryCouch:Collimator:Actual.RVAL
DBR_LONG: 6 0x6
(the voltage varies slightly between the printf and dbgf outputs)
But when Vin is -0.008 V, value is a small negative integer BUT RVAL is
a large positive integer:
readPlcInt, offset=0, value=0xfff4, result=-12 (0xfffffff4)
DBR_LONG: 65524 0xfff4
So it seems RVAL is handled differently than value. Is there some way to make
RVAL behave like value?
Jon Jacky
PS - here are answers to Mark's other questions about MODBUS_DATA and asynReport
In your database for the ai record what is the drvInfo field in the INP link? Is it still MODBUS_DATA? If so, that should be fine.
Yes, dbpr reports the INP field is INP:INST_IO @asynMask(CollimCouch, 0, 16, 1000)MODBUS_DATA
Please send the output of the following command:
asynReport(1, "CollimCouch")
I believe addr 0 is connected to Vin in the output shown above.
epics> asynReport(1, "CollimCouch")
CollimCouch multiDevice:Yes canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 6 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
addr 0 autoConnect Yes enabled Yes connected No exceptionActive No
exceptionActive No exceptionUsers 0 exceptionNotifys 0
blocked No
addr 5 autoConnect Yes enabled Yes connected No exceptionActive No
blocked No
addr 3 autoConnect Yes enabled Yes connected No exceptionActive No
blocked No
addr 4 autoConnect Yes enabled Yes connected No exceptionActive No
blocked No
addr 2 autoConnect Yes enabled Yes connected No exceptionActive No
blocked No
addr 1 autoConnect Yes enabled Yes connected No exceptionActive No
blocked No
modbus port: CollimCouch
asynOctet server: AcromagCollimCouch
modbusSlave: 0
modbusFunction: 4
modbusStartAddress: 00
modbusLength: 011
plcType: AcromagXT1221
I/O errors: 0
Read OK: 2207
Write OK: 0
pollDelay: 0.100000
Time for last I/O 1 msec
Max. I/O time: 7 msec
Time per hist. bin: 1 msec
- Re: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
- RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
RE: areaDetector: plugin in separate dll Mark Rivers
<2015>
<2015>
