Hi Phil,
areaDetector includes an example of such an "optional" plugin, called NDPluginEdge. It is a Canny edge detection plugin using the opencv library.
These are the lines in commonDriverMakefile to include it in any detector applications:
ifdef ADPLUGINEDGE
PROD_LIBS += NDPluginEdge
$(PROD_NAME)_DBD += NDPluginEdge.dbd
ifdef OPENCV_LIB
opencv_core_DIR += $(OPENCV_LIB)
PROD_LIBS += opencv_core opencv_imgproc
else
PROD_SYS_LIBS += opencv_core opencv_imgproc
endif
endif
You just need to add lines like that to your application application Makefile.
The lines about OPENCV are only needed to tell the build system where to look for the opencv header files and libraries. You probably don't need the equivalent of those if your plugin does not rely on a "vendor" library.
The important lines are the first 2:
This is where you tell make to link with your DLL, and to include a .dbd file that you created which contains a single line like:
registrar("NDEdgeRegister")
From: [email protected] [[email protected]] on behalf of Phil Atkin [[email protected]]
Sent: Monday, December 14, 2015 11:48 AM
To: [email protected]
Subject: areaDetector: plugin in separate dll
I've implemented a new plugin that is in a separate dll (i.e. it's not part of NDPlugin.dll).
How should the ADExample detector's makefiles be altered so that the ioc will load it?
Phil Atkin
[cid:[email protected]]Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
- areaDetector: plugin in separate dll Phil Atkin
RE: Newbie: How do I view the output of an areaDetector plugin? Mark Rivers
RE: ai RVAL via asyn + modbus: getting unsigned integer jon
<2015>
areaDetector plugins: what variables can be accessed while unlocked? Phil Atkin
<2015>
