1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: how to build a Easy CA dll and lib for windows-x64
To: Maosong Cheng <[email protected]>, tech-talk <[email protected]>
Date: Sat, 12 Dec 2015 13:14:36 +0000
I forgot to mention that before you build the extensions/src/ezca you must first build EPICS base if you have not already done that.
Sent: Saturday, December 12, 2015 7:12 AM
To: Maosong Cheng; tech-talk
You need to configure an EPICS build system on your windows-x64 system if you have not already done that. This page tells you how to do that.  I recommend using the version of make 4.1 that is linked to on that page.
http://www.aps.anl.gov/epics/base/win32.php
Download the latest version of Extensions Configure files (R3.14) and Easy CA from this link:
http://www.aps.anl.gov/epics/download/extensions/index.php
Go to the extensions/src/ezca directory and read the comments in the Makefile and edit it appropriately depending on whether you want to call Easy CA DLL directly or from another DLL, such as ezcaIDL.
Then type "make".
From: [email protected] [[email protected]] on behalf of Maosong Cheng [[email protected]]
Sent: Saturday, December 12, 2015 5:54 AM
To: tech-talk
Subject: how to build a Easy CA dll and lib for windows-x64
   I use the Easy CA dll and lib on windows-32, now I use it on windows-x64, but I don't know how to build it.
Thanks!
mscheng
how to build a Easy CA dll and lib for windows-x64 Maosong Cheng
RE: how to build a Easy CA dll and lib for windows-x64 Mark Rivers
Prev: RE: how to build a Easy CA dll and lib for windows-x64 Mark Rivers
Next: RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: asynR4-28 available Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
