For whatever it is worth, I also use MSVS2010, but did just grab the most
recent tar from March 2015, that source file does exists in that directory,
but to me, the problem is at the line
process_begin: CreateProcess(NULL
So your version of make might be wrong.
Mark Rivers has been answering 3.15.2 build questions the last couple of
week by stating that he uses make 4.1.
-----Original Message-----
On Behalf Of Mark Rivers
Sent: Thursday, November 05, 2015 5:10 PM
To: 'Klyachko, Alexander Vitalievich' <[email protected]>
Cc: [email protected]
Subject: RE: Building Epics base 3.15.2 in Windows 7
I am not sure what it wrong, perhaps Andrew or someone else has an idea.
I have not tried Visual Studio 2015, I am using 2010.
From: Klyachko, Alexander Vitalievich [mailto:[email protected]]
Sent: Thursday, November 05, 2015 4:39 PM
To: Mark Rivers
Subject: Re: Building Epics base 3.15.2 in Windows 7
I believe VS2015 Professional was downloaded, unfortunately I have no record
of that. I'm pretty sure it is not Express. The output is below.
Thanks much, Alex.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\aklyachk>cd c:\base-3.15.2
c:\base-3.15.2>make --version
GNU Make 4.1
Built for x86_64-w64-mingw32
Copyright (C) 1988-2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
c:\base-3.15.2>make clean uninstall
make -C ./configure clean
make[1]: Entering directory 'c:/base-3.15.2/configure'
perl -CSD -MExtUtils::Command -e rm_rf O.win32-x86 O.Common
make[1]: Leaving directory 'c:/base-3.15.2/configure'
make -C ./src clean
make[1]: Entering directory 'c:/base-3.15.2/src'
make -C ./tools clean
make[2]: Entering directory 'c:/base-3.15.2/src/tools'
make[2]: Leaving directory 'c:/base-3.15.2/src/tools'
make -C tools/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/tools/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/tools/test'
make -C template/base clean
make[2]: Entering directory 'c:/base-3.15.2/src/template/base'
make[2]: Leaving directory 'c:/base-3.15.2/src/template/base'
make -C template/ext clean
make[2]: Entering directory 'c:/base-3.15.2/src/template/ext'
make[2]: Leaving directory 'c:/base-3.15.2/src/template/ext'
make -C ./libCom clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom'
make -C libCom/RTEMS clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom/RTEMS'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom/RTEMS'
make -C libCom/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom/test'
make -C ca/client clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client'
make -C ca/client/tools clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client/tools'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client/tools'
make -C ca/legacy/gdd clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/gdd'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/gdd'
make -C ca/legacy/pcas clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas'
make -C ./build clean
make[3]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/build'
make[3]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/build'
make -C ./example clean
make[3]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/example'
make -C ./directoryService clean
make[4]: Entering directory
'c:/base-3.15.2/src/ca/legacy/pcas/example/directoryService'
make[4]: Leaving directory
make[3]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/example'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas'
make -C ./ioc clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc'
make -C ca/legacy/pcas/ex clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/ex'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/ex'
make -C ca/client/perl clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client/perl'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client/perl'
make -C ioc/db/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc/db/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc/db/test'
make -C ioc/dbtemplate/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc/dbtemplate/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc/dbtemplate/test'
make -C ./std clean
make[2]: Entering directory 'c:/base-3.15.2/src/std'
make[2]: Leaving directory 'c:/base-3.15.2/src/std'
make -C std/filters/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/std/filters/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/std/filters/test'
make -C std/rec/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/std/rec/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/std/rec/test'
make[1]: Leaving directory 'c:/base-3.15.2/src'
perl -CSD -MExtUtils::Command -e rm_rf ./bin/win32-x86
perl -CSD -MExtUtils::Command -e rm_rf ./lib/win32-x86
perl -CSD -MExtUtils::Command -e rm_rf ./dbd ./include ./doc ./html
./templates ./db ./adl ./alh ./cfg ./edl ./lib/perl ./lib/pkgconfig
c:\base-3.15.2>make
make -C ./configure install
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. \
T_A=win32-x86 install
make[2]: Entering directory 'c:/base-3.15.2/configure/O.win32-x86'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'c:/base-3.15.2/configure/O.win32-x86'
make -C ./src install
make -C ./tools install
perl -CSD ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'c:/base-3.15.2/src/tools/O.win32-x86'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/macLib.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Base.pm"
mkdir ../../../lib/perl/DBD
"Installing PERL_MODULES file ../../../lib/perl/DBD/Breaktable.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Device.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Driver.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Function.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Menu.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Output.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Parser.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recfield.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recordtype.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Registrar.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Variable.pm"
"Expanding epics-base-win32-x86.pc@ to epics-base-win32-x86.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-win32-x86.pc"
mkdir ../../../lib/pkgconfig
"Expanding ../epics-base.pc@ to epics-base.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
"Installing created executable ../../../bin/win32-x86/convertRelease.pl"
mkdir ../../../bin/win32-x86
"Installing created executable ../../../bin/win32-x86/cvsclean.pl"
"Installing created executable ../../../bin/win32-x86/dos2unix.pl"
"Installing created executable ../../../bin/win32-x86/expandVars.pl"
"Installing created executable ../../../bin/win32-x86/fullPathName.pl"
"Installing created executable ../../../bin/win32-x86/installEpics.pl"
"Installing created executable ../../../bin/win32-x86/makeIncludeDbd.pl"
"Installing created executable ../../../bin/win32-x86/makeMakefile.pl"
"Installing created executable ../../../bin/win32-x86/makeTestfile.pl"
"Installing created executable ../../../bin/win32-x86/mkmf.pl"
"Installing created executable ../../../bin/win32-x86/munch.pl"
"Installing created executable ../../../bin/win32-x86/replaceVAR.pl"
"Installing created executable ../../../bin/win32-x86/useManifestTool.pl"
"Installing created executable ../../../bin/win32-x86/dbdToMenuH.pl"
"Installing created executable ../../../bin/win32-x86/dbdToRecordtypeH.pl"
"Installing created executable ../../../bin/win32-x86/dbdExpand.pl"
"Installing created executable ../../../bin/win32-x86/dbdToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podRemove.pl"
../../../bin/win32-x86/registerRecordDeviceDriver.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
make[3]: Leaving directory 'c:/base-3.15.2/src/tools/O.win32-x86'
make -C tools/test install
perl -CSD c:/base-3.15.2/bin/win32-x86/makeMakefile.pl O.win32-x86
make -C O.win32-x86 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory 'c:/base-3.15.2/src/tools/test/O.win32-x86'
perl -CSD -MExtUtils::Command -e cp ../Breaktable.plt Breaktable.t
perl -CSD -MExtUtils::Command -e cp ../DBD.plt DBD.t
perl -CSD -MExtUtils::Command -e cp ../Device.plt Device.t
perl -CSD -MExtUtils::Command -e cp ../Driver.plt Driver.t
perl -CSD -MExtUtils::Command -e cp ../Function.plt Function.t
perl -CSD -MExtUtils::Command -e cp ../macLib.plt macLib.t
perl -CSD -MExtUtils::Command -e cp ../Menu.plt Menu.t
perl -CSD -MExtUtils::Command -e cp ../Recfield.plt Recfield.t
perl -CSD -MExtUtils::Command -e cp ../Recordtype.plt Recordtype.t
perl -CSD -MExtUtils::Command -e cp ../Registrar.plt Registrar.t
perl -CSD -MExtUtils::Command -e cp ../Variable.plt Variable.t
make[3]: Leaving directory 'c:/base-3.15.2/src/tools/test/O.win32-x86'
make -C template/base install
make[3]: Entering directory 'c:/base-3.15.2/src/template/base/O.win32-x86'
"Installing created executable ../../../../bin/win32-x86/makeBaseApp.pl"
"Installing ../../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseApp/top/configure
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp
"Installing ../../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/src
"Installing
../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp
"Installing ../../../../templates/makeBaseApp/top/iocApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/Db
"Installing ../../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/src
"Installing
../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/Db
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/src
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocBoot
"Installing
../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make[3]: Leaving directory 'c:/base-3.15.2/src/template/base/O.win32-x86'
make -C template/ext install
make[3]: Entering directory 'c:/base-3.15.2/src/template/ext/O.win32-x86'
"Installing created executable ../../../../bin/win32-x86/makeBaseExt.pl"
"Installing ../../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
"Installing ../../../../templates/makeBaseExt/top/README"
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseExt/top/configure
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-p
pc"
mkdir ../../../../templates/makeBaseExt/top/configure/os
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc
64-gnu.solaris-sparc64-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_6
4.freebsd-x86_64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.da
rwin-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-38
6"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cy
gwin-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_6
4.solaris-x86_64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.lin
ux-ppc"
"Installing
-debug.solaris-sparc-debug"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.w
indows-x64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-deb
ug.win32-x86-debug"
"Installing
.solaris-sparc"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win
32-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-deb
ug.linux-x86-debug"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cyg
win.win32-x86-cygwin"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.lin
ux-x86"
"Installing
64.solaris-sparc64"
"Installing
-gnu.solaris-sparc-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86
.darwin-ppcx86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-d
ebug.solaris-x86-debug"
"Installing
ux-athlon"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.s
olaris-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-g
nu.solaris-x86-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.a
ix-ppc-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-
debug.linux-x86_64-debug"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-min
gw.win32-x86-mingw"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.
linux-x86_64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.da
rwin-ppc"
"Installing ../../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../../templates/makeBaseExt/top/src
"Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing
../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory 'c:/base-3.15.2/src/template/ext/O.win32-x86'
make -C ./libCom install
perl -CSD c:/base-3.15.2/bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
make[3]: Entering directory 'c:/base-3.15.2/src/libCom/O.win32-x86'
perl -CSD ../../../src/libCom/misc/makeEpicsVersion.pl -o epicsVersion.h
../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.15.2
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m forceBadAllocException.d
-I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc
-I../../../src/libCom/osi/compiler/default -I. -I../
../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/as -I../../../src/libCom/bucketLib
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I..
/../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCo
m/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../s
rc/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool
-I../../../src/libCom/ring -I../../../src/libCom/taskwd
-I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../
src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc
-I../../../include/os/WIN32 -I../../../include
forceBadAllocException.d ../../../src/libCom/osi/os/WIN32/f
orceBadAllocException.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m setThreadName.d -I.
-I../../../src/libCom/osi/compiler/default -I. -I../../../src
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../sr
-I../../../src/libCom/fdmgr -
-I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom
-I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCo
-I../../../include/os/WIN32 -I../../../include setThreadName.d
../../../src/libCom/osi/os/WIN32/setThreadName.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsGetopt.d -I.
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/
libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
-I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I.
-I../../../include/os/WIN32 -I../../../include epicsGetopt.d
../../../src/libCom/osi/os/WIN32/epicsGetopt.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_parser.d -I.
-I../../../include/os/WIN32 -I../../../include yajl_parser.d
../../../src/libCom/yajl/yajl_parser.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_lex.d -I.
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/lib
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../.
-I../../../src/libCom/misc
-I../../../include/os/WIN32 -I../../../include yajl_lex.d
../../../src/libCom/yajl/yajl_lex.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_gen.d -I.
-I../../../include/os/WIN32 -I../../../include yajl_gen.d
../../../src/libCom/yajl/yajl_gen.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_encode.d -I.
-I../../../include/os/WIN32 -I../../../include yajl_encode.d
../../../src/libCom/yajl/yajl_encode.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_buf.d -I.
-I../../../include/os/WIN32 -I../../../include yajl_buf.d
../../../src/libCom/yajl/yajl_buf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_alloc.d -I.
-I../../../include/os/WIN32 -I../../../include yajl_alloc.d
../../../src/libCom/yajl/yajl_alloc.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl.d -I. -I../O.Common
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/o
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../..
/src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash
-I../../../src/libCom/iocsh -I../../../src/libCom/log
-I../../../src/libCom/macLib -I../../../src/libCom/misc -I.
./../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/yacc -I../../../src/libCom/yacc -I
-I../../../include/os/WIN32 -I../../../include yajl.d
../../../src/libCom/yajl/yajl.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueuePassive.d -I.
-I../../../include/os/WIN32 -I../../../include timerQueuePassive.d
../../../src/libCom/timer/timerQueuePassive.
cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueueActiveMgr.d -I.
-I../../../include/os/WIN32 -I../../../include timerQueueActiveMgr.d
../../../src/libCom/timer/timerQueueActi
veMgr.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueueActive.d -I.
-I../../../include/os/WIN32 -I../../../include timerQueueActive.d
../../../src/libCom/timer/timerQueueActive.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueue.d -I.
-I../../../include/os/WIN32 -I../../../include timerQueue.d
../../../src/libCom/timer/timerQueue.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timer.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include timer.d
../../../src/libCom/timer/timer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsTimer.d -I.
-I../../../include/os/WIN32 -I../../../include epicsTimer.d
../../../src/libCom/timer/epicsTimer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m taskwd.d -I.
-I../../../include/os/WIN32 -I../../../include taskwd.d
../../../src/libCom/taskwd/taskwd.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsRingBytes.d -I.
-I../../../include/os/WIN32 -I../../../include epicsRingBytes.d
../../../src/libCom/ring/epicsRingBytes.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsRingPointer.d -I.
-I../../../include/os/WIN32 -I../../../include epicsRingPointer.d
../../../src/libCom/ring/epicsRingPointer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m threadPool.d -I.
-I../../../include/os/WIN32 -I../../../include threadPool.d
../../../src/libCom/pool/threadPool.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m poolJob.d -I.
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libC
-I../../../include/os/WIN32 -I../../../include poolJob.d
../../../src/libCom/pool/poolJob.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdFindAddr.d -I.
-I../../../include/os/WIN32 -I../../../include osdFindAddr.d
../../../src/libCom/osi/os/default/osdFindAddr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdBackTrace.d -I.
/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
-I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom
-I../../../include/os/WIN32 -I../../../include osdBackTrace.d
../../../src/libCom/osi/os/WIN32/osdBackTrace.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsStackTrace.d -I.
-I../../../include/os/WIN32 -I../../../include epicsStackTrace.d
../../../src/libCom/osi/epicsStackTrace.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m devLibVMEOSD.d -I.
-I../../../include/os/WIN32 -I../../../include devLibVMEOSD.d
../../../src/libCom/osi/os/default/devLibVMEOSD.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m devLibVME.d -I.
-I../../../include/os/WIN32 -I../../../include devLibVME.d
../../../src/libCom/osi/devLibVME.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdMessageQueue.d -I.
-I../../../include/os/WIN32 -I../../../include osdMessageQueue.d
../../../src/libCom/osi/os/default/osdMessageQue
ue.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdNetIntf.d -I.
-I../../../include/os/WIN32 -I../../../include osdNetIntf.d
../../../src/libCom/osi/os/WIN32/osdNetIntf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdProcess.d -I.
-I../../../include/os/WIN32 -I../../../include osdProcess.d
../../../src/libCom/osi/os/WIN32/osdProcess.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdTime.d -I.
-I../../../include/os/WIN32 -I../../../include osdTime.d
../../../src/libCom/osi/os/WIN32/osdTime.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdEvent.d -I.
-I../../../include/os/WIN32 -I../../../include osdEvent.d
../../../src/libCom/osi/os/WIN32/osdEvent.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSpin.d -I.
-I../../../include/os/WIN32 -I../../../include osdSpin.d
../../../src/libCom/osi/os/default/osdSpin.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdMutex.d -I.
-I../../../include/os/WIN32 -I../../../include osdMutex.d
../../../src/libCom/osi/os/WIN32/osdMutex.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdThreadHooks.d -I.
-I../../../include/os/WIN32 -I../../../include osdThreadHooks.d
../../../src/libCom/osi/os/default/osdThreadHooks.
c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdThreadExtra.d -I.
-I../../../include/os/WIN32 -I../../../include osdThreadExtra.d
../../../src/libCom/osi/os/WIN32/osdThreadExtra.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdThread.d -I.
-I../../../include/os/WIN32 -I../../../include osdThread.d
../../../src/libCom/osi/os/WIN32/osdThread.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdStdio.d -I.
-I../../../include/os/WIN32 -I../../../include osdStdio.d
../../../src/libCom/osi/os/WIN32/osdStdio.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsStdio.d -I.
-I../../../include/os/WIN32 -I../../../include epicsStdio.d
../../../src/libCom/osi/epicsStdio.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsTempFile.d -I.
-I../../../include/os/WIN32 -I../../../include epicsTempFile.d
../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsReadline.d -I.
-I../../../include/os/WIN32 -I../../../include epicsReadline.d
../../../src/libCom/osi/os/default/epicsReadline.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdEnv.d -I.
-I../../../include/os/WIN32 -I../../../include osdEnv.d
../../../src/libCom/osi/os/default/osdEnv.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSignal.d -I.
-I../../../include/os/WIN32 -I../../../include osdSignal.d
../../../src/libCom/osi/os/WIN32/osdSignal.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdPoolStatus.d -I.
-I../../../include/os/WIN32 -I../../../include osdPoolStatus.d
../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdInterrupt.d -I.
-I../../../include/os/WIN32 -I../../../include osdInterrupt.d
../../../src/libCom/osi/os/default/osdInterrupt.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdFindSymbol.d -I.
-I../../../include/os/WIN32 -I../../../include osdFindSymbol.d
../../../src/libCom/osi/os/WIN32/osdFindSymbol.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdAssert.d -I.
-I../../../include/os/WIN32 -I../../../include osdAssert.d
../../../src/libCom/osi/os/default/osdAssert.c
epicsSocketConvertErrnoToString.d -I. -I../O.Common -I.
-I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
-I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib
Fast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList
./../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool
../../../src/libCom/yacc -I../../../src/libCom/yajl
-I../../../include/compiler/msvc -I../../../include/os/WIN32
-I../../../include epicsSocketConvertErrnoToString.d
../../../src/lib
Com/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m systemCallIntMech.d -I.
-I../../../include/os/WIN32 -I../../../include systemCallIntMech.d
../../../src/libCom/osi/os/WIN32/systemCallI
ntMech.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osiSock.d -I.
-I../../../include/os/WIN32 -I../../../include osiSock.d
../../../src/libCom/osi/osiSock.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSockAddrReuse.d -I.
-I../../../include/os/WIN32 -I../../../include osdSockAddrReuse.d
../../../src/libCom/osi/os/WIN32/osdSockAddrRe
use.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSock.d -I.
-I../../../include/os/WIN32 -I../../../include osdSock.d
../../../src/libCom/osi/os/WIN32/osdSock.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osiClockTime.d -I.
-I../../../include/os/WIN32 -I../../../include osiClockTime.d
../../../src/libCom/osi/osiClockTime.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsGeneralTime.d -I.
-I../../../include/os/WIN32 -I../../../include epicsGeneralTime.d
../../../src/libCom/osi/epicsGeneralTime.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsAtomicOSD.d -I.
-I../../../include/os/WIN32 -I../../../include epicsAtomicOSD.d
../../../src/libCom/osi/os/default/epicsAtomicOSD.
cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsMath.d -I.
-I../../../include/os/WIN32 -I../../../include epicsMath.d
../../../src/libCom/osi/epicsMath.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsMessageQueue.d -I.
-I../../../include/os/WIN32 -I../../../include epicsMessageQueue.d
../../../src/libCom/osi/epicsMessageQueue.cp
p
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsTime.d -I.
-I../../../include/os/WIN32 -I../../../include epicsTime.d
../../../src/libCom/osi/epicsTime.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsEvent.d -I.
-I../../../include/os/WIN32 -I../../../include epicsEvent.d
../../../src/libCom/osi/epicsEvent.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsMutex.d -I.
-I../../../include/os/WIN32 -I../../../include epicsMutex.d
../../../src/libCom/osi/epicsMutex.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsThread.d -I.
-I../../../include/os/WIN32 -I../../../include epicsThread.d
../../../src/libCom/osi/epicsThread.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsUnitTest.d -I.
-I../../../include/os/WIN32 -I../../../include epicsUnitTest.d
../../../src/libCom/misc/epicsUnitTest.c
ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I.
../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
-I../../../include ipAddrToAsciiAsynchronous.d
../../../src/libCom/misc/ipA
ddrToAsciiAsynchronous.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m truncateFile.d -I.
-I../../../include/os/WIN32 -I../../../include truncateFile.d
../../../src/libCom/misc/truncateFile.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsString.d -I.
-I../../../include/os/WIN32 -I../../../include epicsString.d
../../../src/libCom/misc/epicsString.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsStdlib.d -I.
-I../../../include/os/WIN32 -I../../../include epicsStdlib.d
../../../src/libCom/misc/epicsStdlib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsExit.d -I.
-I../../../include/os/WIN32 -I../../../include epicsExit.d
../../../src/libCom/misc/epicsExit.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsConvert.d -I.
-I../../../include/os/WIN32 -I../../../include epicsConvert.d
../../../src/libCom/misc/epicsConvert.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m cantProceed.d -I.
-I../../../include/os/WIN32 -I../../../include cantProceed.d
../../../src/libCom/misc/cantProceed.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m adjustment.d -I.
-I../../../include/os/WIN32 -I../../../include adjustment.d
../../../src/libCom/misc/adjustment.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m aToIPAddr.d -I.
-I../../../include/os/WIN32 -I../../../include aToIPAddr.d
../../../src/libCom/misc/aToIPAddr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m alarmString.d -I.
-I../../../include/os/WIN32 -I../../../include alarmString.d
../../../src/libCom/misc/alarmString.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m macUtil.d -I.
-I../../../include/os/WIN32 -I../../../include macUtil.d
../../../src/libCom/macLib/macUtil.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m macEnv.d -I.
-I../../../include/os/WIN32 -I../../../include macEnv.d
../../../src/libCom/macLib/macEnv.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m macCore.d -I.
-I../../../include/os/WIN32 -I../../../include macCore.d
../../../src/libCom/macLib/macCore.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m logClient.d -I.
-I../../../include/os/WIN32 -I../../../include logClient.d
../../../src/libCom/log/logClient.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m iocLog.d -I.
-I../../../include/os/WIN32 -I../../../include iocLog.d
../../../src/libCom/log/iocLog.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m libComRegister.d -I.
-I../../../include/os/WIN32 -I../../../include libComRegister.d
../../../src/libCom/iocsh/libComRegister.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m registry.d -I.
-I../../../include/os/WIN32 -I../../../include registry.d
../../../src/libCom/iocsh/registry.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m iocsh.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include iocsh.d
../../../src/libCom/iocsh/iocsh.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m gpHashLib.d -I.
-I../../../include/os/WIN32 -I../../../include gpHashLib.d
../../../src/libCom/gpHash/gpHashLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m freeListLib.d -I.
-I../../../include/os/WIN32 -I../../../include freeListLib.d
../../../src/libCom/freeList/freeListLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m fdManager.d -I.
-I../../../include/os/WIN32 -I../../../include fdManager.d
../../../src/libCom/fdmgr/fdManager.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m fdmgr.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include fdmgr.d
../../../src/libCom/fdmgr/fdmgr.cpp
perl -CSD ../../../src/libCom/error/makeStatTbl.pl
../../../src/libCom/osi/devLib.h ../../../src/libCom/as/asLib.h
../../../src/libCom/misc/epicsStdlib.h ../../../src/libCom/pool/epicsThrea
dPool.h ../../../src/ioc/db/dbAccessDefs.h
../../../src/ioc/dbStatic/devSup.h ../../../src/ioc/dbStatic/drvSup.h
../../../src/ioc/dbStatic/recSup.h ../../../src/ioc/dbStatic/dbStaticLib.h
/../../src/libCom/error/errMdef.h
../../../src/ca/legacy/pcas/generic/casdef.h
../../../src/ca/legacy/gdd/gddAppFuncTable.h
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m errSymTbl.d -I.
-I../../../include/os/WIN32 -I../../../include errSymTbl.d
errSymTbl.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m errSymLib.d -I.
-I../../../include/os/WIN32 -I../../../include errSymLib.d
../../../src/libCom/error/errSymLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m errlog.d -I.
-I../../../include/os/WIN32 -I../../../include errlog.d
../../../src/libCom/error/errlog.c
perl -CSD ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m envData.d -I.
-I../../../include/os/WIN32 -I../../../include envData.d envData.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m envSubr.d -I.
-I../../../include/os/WIN32 -I../../../include envSubr.d
../../../src/libCom/env/envSubr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m ellLib.d -I.
-I../../../include/os/WIN32 -I../../../include ellLib.d
../../../src/libCom/ellLib/ellLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m dbmf.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include dbmf.d
../../../src/libCom/dbmf/dbmf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsSingletonMutex.d -I.
-I../../../include/os/WIN32 -I../../../include epicsSingletonMutex.d
../../../src/libCom/cxxTemplates/epicsSi
ngletonMutex.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsOnce.d -I.
-I../../../include/os/WIN32 -I../../../include epicsOnce.d
../../../src/libCom/cxxTemplates/epicsOnce.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m resourceLib.d -I.
-I../../../include/os/WIN32 -I../../../include resourceLib.d
../../../src/libCom/cxxTemplates/resourceLib.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m cvtFast.d -I.
-I../../../include/os/WIN32 -I../../../include cvtFast.d
../../../src/libCom/cvtFast/cvtFast.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m calcPerform.d -I.
-I../../../include/os/WIN32 -I../../../include calcPerform.d
../../../src/libCom/calc/calcPerform.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m postfix.d -I.
-I../../../include/os/WIN32 -I../../../include postfix.d
../../../src/libCom/calc/postfix.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m bucketLib.d -I.
-I../../../include/os/WIN32 -I../../../include bucketLib.d
../../../src/libCom/bucketLib/bucketLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m asTrapWrite.d -I.
-I../../../include/os/WIN32 -I../../../include asTrapWrite.d
../../../src/libCom/as/asTrapWrite.c
"Installing generic include file ../../../include/asLib.h"
mkdir ../../../include
"Installing generic include file ../../../include/asTrapWrite.h"
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/flex.skel.static"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/alarm.h"
"Installing generic include file ../../../include/alarmString.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
../../../include/ipAddrToAsciiAsynchronous.h"
"Installing generic include file ../../../include/compilerDependencies.h"
"Installing generic include file ../../../include/epicsUnitTest.h"
"Installing generic include file ../../../include/testMain.h"
"Installing generated generic include file ../../../include/epicsVersion.h"
"Installing compiler dependent include file
../../../include/compiler/msvc/compilerSpecific.h"
mkdir ../../../include/compiler
mkdir ../../../include/compiler/msvc
"Installing OS dependent include file
../../../include/os/WIN32/osiFileName.h"
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsSpin.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMath.h"
../../../include/os/WIN32/osdMessageQueue.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
../../../include/os/WIN32/osdPoolStatus.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing OS dependent include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
../../../include/os/WIN32/osdWireFormat.h"
../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsAtomic.h"
"Installing generic include file ../../../include/epicsAtomicDefault.h"
../../../include/os/WIN32/epicsAtomicOSD.h"
../../../include/compiler/msvc/epicsAtomicCD.h"
"Installing generic include file ../../../include/epicsEndian.h"
../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
"Installing generic include file ../../../include/epicsTempFile.h"
../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../include/epicsStackTrace.h"
"Installing generic include file ../../../include/devLib.h"
"Installing generic include file ../../../include/devLibVME.h"
"Installing generic include file ../../../include/devLibVMEImpl.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdVME.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMMIO.h"
../../../include/os/WIN32/epicsMMIODef.h"
"Installing generic include file ../../../include/epicsThreadPool.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/yajl_common.h"
"Installing generic include file ../../../include/yajl_gen.h"
"Installing generic include file ../../../include/yajl_parse.h"
../../../include/os/WIN32/epicsAtomicMS.h"
cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MD
-DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I
-I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
-I../../..
/src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd
dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/l
ibCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log
-I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src
/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../.
./../include/os/WIN32 -I../../../include -c
process_begin: CreateProcess(NULL, cl -EHsc -GR -nologo -D__STDC__=0
-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3
-w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -T
P -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc
-I
-I../../../src
/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log
-I../../../src/libCom/yacc -I../../../src/libCom/yajl
c -I../../../include/os/WIN32 -I../../../include -c
../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp, ...) failed.
make (e=2): The system cannot find the file specified.
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m warshall.d -I.
-I../../../include/os/WIN32 -I../../../include warshall.d
../../../src/libCom/yacc/warshall.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m verbose.d -I.
-I../../../include/os/WIN32 -I../../../include verbose.d
../../../src/libCom/yacc/verbose.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m symtab.d -I.
-I../../../include/os/WIN32 -I../../../include symtab.d
../../../src/libCom/yacc/symtab.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m skeleton.d -I.
-I../../../include/os/WIN32 -I../../../include skeleton.d
../../../src/libCom/yacc/skeleton.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m reader.d -I.
-I../../../include/os/WIN32 -I../../../include reader.d
../../../src/libCom/yacc/reader.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m output.d -I.
-I../../../include/os/WIN32 -I../../../include output.d
../../../src/libCom/yacc/output.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m mkpar.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include mkpar.d
../../../src/libCom/yacc/mkpar.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m antelope.d -I.
-I../../../include/os/WIN32 -I../../../include antelope.d
../../../src/libCom/yacc/antelope.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m lr0.d -I. -I../O.Common
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../
-I../../../src/libCom/macLib -I../../../src/libCom/misc -I..
-I../../../src/libCom/yacc -I../../../src/libCom/yacc -I.
-I../../../include/os/WIN32 -I../../../include lr0.d
../../../src/libCom/yacc/lr0.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m lalr.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include lalr.d
../../../src/libCom/yacc/lalr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m error.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include error.d
../../../src/libCom/yacc/error.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m closure.d -I.
-I../../../include/os/WIN32 -I../../../include closure.d
../../../src/libCom/yacc/closure.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m iocLogServer.d -I.
-I../../../include/os/WIN32 -I../../../include iocLogServer.d
../../../src/libCom/log/iocLogServer.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m tblcmp.d -I.
-I../../../include/os/WIN32 -I../../../include tblcmp.d
../../../src/libCom/flex/tblcmp.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m sym.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include sym.d
../../../src/libCom/flex/sym.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m nfa.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include nfa.d
../../../src/libCom/flex/nfa.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m misc.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include misc.d
../../../src/libCom/flex/misc.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m gen.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include gen.d
../../../src/libCom/flex/gen.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m ecs.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include ecs.d
../../../src/libCom/flex/ecs.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m dfa.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include dfa.d
../../../src/libCom/flex/dfa.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m ccl.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include ccl.d
../../../src/libCom/flex/ccl.c
-I../../..
-I
-I../../../src
make[3]: *** No rule to make target 'epicsTempFile.obj', needed by
'antelope.exe'. Stop.
make[3]: Leaving directory 'c:/base-3.15.2/src/libCom/O.win32-x86'
../../configure/RULES_ARCHS:61: recipe for target 'install.win32-x86' failed
make[2]: *** [install.win32-x86] Error 2
../configure/RULES_DIRS:88: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
c:\base-3.15.2>
Sent: Thursday, November 5, 2015 11:36 AM
To: Klyachko, Alexander Vitalievich; [email protected]
Cc: Alexander Klyachko
What version of Visual Studio 2015 are you using (Express, Community,
Professional, etc.)? There is a known problem with Express:
http://www.aps.anl.gov/epics/base/R3-15/2-docs/KnownProblems.html
If you not using Express then please send the complete output of the
following at the top-level of EPICS base 3.15.2:
make --version
make
Sent: Thursday, November 05, 2015 10:14 AM
To: Mark Rivers; [email protected]
Hi Mark,
Thanks for your reply.
I followed the instructions in the link you provided.
I'm using make 4.1, still get the error messages:
-w44355 -MD -DEPICS
_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I.
Com/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
om/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c
Alex.
Alexander V. Klyachko, Ph.D.
Senior Research Scientist,
Phenix Medical LLC,
120 West 7th St., Suite 313
Bloomington, IN 47404
(812)361-4445
Sent: Wednesday, November 4, 2015 5:20 PM
There was a tech-talk thread about this recently.
http://www.aps.anl.gov/epics/tech-talk/2015/msg01572.php
For 3.15.2 you must use make 4.1. You can find a link to it here:
http://www.aps.anl.gov/epics/base/win32.php
behalf of Klyachko, Alexander Vitalievich [[email protected]]
Sent: Wednesday, November 04, 2015 4:14 PM
To: [email protected]
Subject: Building Epics base 3.15.2 in Windows 7
Hi all,
I'm stuck trying to build Epics base in Windows 7. The system is:
Windows 7 Professional
Epics base-3.15.2
Visual Studio 2015
GnuWin32
Strawberry Perl 5.22
Does anybody know what is going on here?
Alex.
-w44355 -MD -DEPICS
-w44355 -MD -DEPICS
- Re: Building Epics base 3.15.2 in Windows 7 Andrew Johnson
- Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
- RE: Building Epics base 3.15.2 in Windows 7 Mark Rivers
- Re: Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
RE: Building Epics base 3.15.2 in Windows 7 Mark S. Engbretson
<2015>
<2015>
