Hi Tim,
Please look at this page:
http://www.aps.anl.gov/epics/base/win32.php
It gives the recommended versions of gnumake and Perl. Note that for 3.15.2 you must use make 4.1, as documented on that page. Here is a link to download that for Windows:
http://www.aps.anl.gov/epics/download/tools/make-4.1-win64.zip
For building with Visual Studio you should not use Cygwin at all. Make sure Cygwin is not in your path, and use a Windows cmd command shell.
For building base 3.15.2 with Visual Studio 2015 you need to look at the Known Problems page here.
http://www.aps.anl.gov/epics/base/R3-15/2-docs/KnownProblems.html
It says that you cannot use the Express Edition, you must use the Community Edition (or presumably the licensed version). You also must apply a patch to base as documented on that page.
Sent: Friday, October 02, 2015 5:20 PM
To: Madden, Timothy J.
Cc: [email protected]
Subject: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2
It looks like you are using Cgywin make. That is not allowed. See. The page on building with Windows on EPICS base page. Use make 4.1 linked to there.
Sent from my iPhone
> On Oct 2, 2015, at 5:15 PM, Madden, Timothy J. <[email protected]> wrote:
> Mark
> Thanks for the reply.
> Here is the error message. I saw someone else had gotten a similar message. With other epics base it goes away, but the 2015 compiler does not work with older EPICS.
> Tim
> See below-----------------------------------------------
> D:\EPICS\ADEpics\synApps_5_5\support\seq-2.2.3>make
> cygwin warning:
> MS-DOS style path detected: D:/EPICS/ADEpics/base-3.15.2/configure/CONFIG
> Preferred POSIX equivalent is: /cygdrive/d/EPICS/ADEpics/base-3.15.2/configure
> /CONFIG
> CYGWIN environment variable option "nodosfilewarning" turns off this warning.
> Consult the user's guide for more details about POSIX paths:
> http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
> make -C ./configure install
> make[1]: Entering directory `/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2
> .2.3/configure'
> perl -CSD /cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.2.3/configure/D:/E
> PICS/ADEpics/base-3.15.2/bin/windows-x64-debug/makeMakefile.pl O.windows-x64-deb
> ug ../..
> Can't open perl script "/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.2.3/
> configure/D:/EPICS/ADEpics/base-3.15.2/bin/windows-x64-debug/makeMakefile.pl": N
> o such file or directory
> make[1]: *** [O.windows-x64-debug] Error 2
> make[1]: Leaving directory `/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.
> 2.3/configure'
> make: *** [configure.install] Error 2
> -----------------------------------------------END------------------------------------------------
> From: Mark Rivers [[email protected]]
> Sent: Friday, October 02, 2015 4:50 PM
> 2.2.3 does work for me with VS 2010 and 3.14.12.5. It was 2.2.2 that did not work. I have not tested your combination of compiler and base, but please send the error message.
> Mark
> Sent from my iPhone
> On Oct 2, 2015, at 4:20 PM, Madden, Timothy J. <[email protected]<mailto:[email protected]>> wrote:
> Dear EPICS:
> Trying to build seq 2.2.3 with epics base 3.15.2. I am using the windows 2015 compiler on a 64 bit machine.
> I am building in 64 bit mode.
> I saw some tech talk notes that this does not work?
> Mark R. says one can make this work with 2.2.x snapshot etc. etc. I don't know where to get this. it is not on the seq web site.
> Thanks
> Tim Madden
> APS
- RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 freddie.akeroyd
- Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Mark Rivers
- RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
<2015>
<2015>
