1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Looking at ethercat and EPICS
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Wed, 21 Oct 2015 09:28:25 +0000
Hello,
I paste below a table from Diamond’s list of ethercat supported modules.
We have more experience with some models and less with others. For example, even though the EL1502 is listed, I am not aware of it being used in our facility.
There are two sections, the DIN rail modules (EL and EK prefix) and the box IO modules (EP prefix).
Regarding the template that you mention, gadc stands for “generic adc”, not gated adc.
There is some documentation here
http://controls.diamond.ac.uk/downloads/support/ethercat/4-3/documentation/doxygen/generic_adc.html
We don’t currently have gating or triggering for these modules.
Ronaldo
Part No.
Type
Description
Typical Applications
EL3104
Analogue Input
16 bit (incl. sign), -10 to +10V dc, differential i/p
General purpose
EL3124
Analogue Input
16 bit (incl. sign), 4 to 20mA, differential i/p
General purpose
EL3602
Analogue Input
24 bit (incl. sign), -10 to +10V (scalable), differential i/p
High accuracy i/p: Femto amplifier o/p
EL3702
Analogue Input
16 bit (incl. sign), -10 to +10V dc, oversampling, diff. i/p
Fast i/p: vacuum gauge controllers
EL3202-0010
RTD / PT100 Input
0.01⁰C/digit, 4 wire connection
General purpose / high precision
EL3314
Thermocouple Input
0.1⁰C/digit, open circuit recognition
General purpose
EL4134
Analogue Output
16 bit, -10 to +10V dc.
General purpose
EL4732
Analogue Output
Fast o/p
EL1014
Digital Input
24V dc input, 10µs i/p filter
General purpose. Suitable for fast i/p.
EL1124
Digital Input
5V dc input, 0.05µs i/p filter
TTL i/p. See EL9505 for 5V supply module.
EL1502
Counter Input
24V dc up/down counter, 100kHz max. frequency
General purpose
EL2612
Digital Output
Relay o/p, 2 x changeover, 2A @ 24V dc.
General purpose
EL2624
Digital Output
Relay o/p, 4 x normally open, 2A @ 24V dc.
General purpose
EL2024
Digital Output
24V dc output, 2A @ 24V dc.
General purpose
EL2024-0010
Digital Output
12V dc output, 2A @ 12V dc.
General purpose: Femto amplifier o/p
EL2124
Digital Output
5V dc fast output, +/- 20mA per channel
TTL o/p. See EL9505 for 5V supply module.
EL2595
Digital Output
LED constant current terminal
LED control e.g. backlights
EK1100
EtherCAT Coupler Unit
EtherCAT coupler.
Standard Diamond coupler
EL9011
End Cap
End Cap
Fitted to last module in node.
EK1122
EtherCAT Junction
2 port EtherCAT junction
If a star type connection needed.
EL9410
Supply Terminal
2A Power supply module for E-bus, 24V dc.
Needed every time E-bus current > 2A.
EL9080
Separation Terminal
Dumb module inserted between two potential groups
Separation of 24V dc and 5V dc i/o
EL9512
12V dc Power Supply
Power supply module, 24V dc i/p, 12V 0.5A dc o/p.
Supply for 12V modules.
EL9505
5V dc Power Supply
Power supply module, 24V dc i/p, 5V 0.5A dc o/p.
Supply for 5V modules.
EL9185
Potential Distribution
Potential distributor, 4 terminal points
24V dc terminals from the I/O power rail.
EP3174-0002
Analogue Input
4
16 bit (incl. sign), individual parameterised differential i/p
General purpose
EP3204-0002
RTD / PT100 Input
4
0.1⁰C/digit, 2,3,4 wire connection, open circuit recognition
General purpose
EP3314-0002
Thermocouple / mV Input
4
General purpose
ZS2000-3712
NA
M12 thermocouple connecting plug c/w temp. comp.
Order if using EP3314-0002
EP4174-0002
Analogue Output
4
16 bit, individual parameterised o/p
General purpose
EP4374-0002
Analogue Combi
4
16 bit, 2 ch. input & 2 ch. Output individual parameterised
General purpose
EP2338-0002
Digital Combi
8
24V dc freely configurable digital input (10µs) / output
General purpose
EP2624-0002
Digital Output
4
Relay o/p, 2A @ 24V dc.
General purpose
EP1122-0001
EtherCAT Junction
NA
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Williams Jr., Ernest L.
> Sent: 20 October 2015 16:30
> To: [email protected]
> Cc: Vasquez Stanescu, Jesus A; Balakrishnan, Namrata
> Subject: Looking at ethercat and EPICS
> Hi everyone,
> Looking for the EtherCAT users out there. :)
> Currently, we are working with the "dls-ethercat EPICS Support Module"
> I am currently using version "ethercat-4-1"
> Can someone send me a reference to the recommended hardware for general
> purpose I/O (e.g. digital I/O and analog I/O) ?
> For example, in the package from the Diamond Light Source, I see
> templates for gated ADC (i.e. gadc.template).
> These templates are referenced in the scanTest  "iocs" application.
> However, I would like to get the hardware details such as model number,
> manufacturer, etc ...
> Of course, the beckhoff model numbers such as "EL1502" are familiar.
> Cheers,
> Ernest
Looking at ethercat and EPICS Williams Jr., Ernest L.
Prev: RE: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays Mark Rivers
Next: RE: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays Mazanec Tomáš
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Looking at ethercat and EPICS Williams Jr., Ernest L.
Next: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays bohmm
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
