Subject: |
Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays |
bohmm <[email protected]> |
To: |
Tech talk <[email protected]> |
Date: |
Tue, 20 Oct 2015 18:51:35 +0200 |
Hello,
I have problems in reading internal relay values from an IDEC PLC. The
function code used and the Modbus addresses should be alright, when I
set the internal relays (nine of them) all to high and try to debug
using asynTrace, I got from modbus port driver:
00 00 00 00 00 00 01 00 00 00 01 00 01 00 01 00 00 00
2015/10/20 16:13:13.014 drvModbusAsyn::doModbusIO port BI READ_COILS
and from drvAsynIPPort driver:
2015/10/20 16:24:46.868 192.168.1.5:502 write 12
00 01 00 00 00 06 01 01 03 e8 00 09
The values from the port driver debug output do not match with the
internal relay values and furthermore, when I change one of the internal
relay's value, it is not changed in the modbus port driver debug output.
When I try in iocsh >>asynReport:
BI multiDevice:Yes canBlock:No autoConnect:Yes
addr 0 autoConnect Yes enabled Yes connected No exceptionActive No
addr 1 autoConnect Yes enabled Yes connected No exceptionActive No
addr 2 autoConnect Yes enabled Yes connected No exceptionActive No
addr 3 autoConnect Yes enabled Yes connected No exceptionActive No
addr 4 autoConnect Yes enabled Yes connected No exceptionActive No
addr 5 autoConnect Yes enabled Yes connected No exceptionActive No
addr 6 autoConnect Yes enabled Yes connected No exceptionActive No
addr 7 autoConnect Yes enabled Yes connected No exceptionActive No
addr 8 autoConnect Yes enabled Yes connected No exceptionActive No
modbus port: BI
And iocsh for a "BI" modbus port driver:
epics> asynReport 5, "BI"
enabled:Yes connected:Yes numberConnects 1
nDevices 9 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
interfaceList
asynCommon pinterface 0x7f2bce127ae0 drvPvt 0xd2bcc0
asynDrvUser pinterface 0x7f2bce128110 drvPvt 0xd2bcc0
asynUInt32Digital pinterface 0x7f2bce128140 drvPvt 0xd2bcc0
asynInt32 pinterface 0x7f2bce128180 drvPvt 0xd2bcc0
asynFloat64 pinterface 0x7f2bce1281c0 drvPvt 0xd2bcc0
asynInt32Array pinterface 0x7f2bce1281e0 drvPvt 0xd2bcc0
exceptionActive No exceptionUsers 0 exceptionNotifys 0
blocked No
blocked No
blocked No
blocked No
blocked No
blocked No
blocked No
blocked No
blocked No
modbus port: BI
asynOctet server: IDEC
modbusSlave: 1
modbusFunction: 1
modbusStartAddress: 01750
modbusLength: 011
plcType: IDEC_PLC_message
I/O errors: 0
Read OK: 2146
Write OK: 0
pollDelay: 0.100000
Time for last I/O 1 msec
Max. I/O time: 7 msec
I guess that the message connected No points to the problem...but here
is where I got stuck.
My st.cmd and .substitution files follow are below.
Best regards
Marek Böhm
My st.cmd:
#!../../bin/linux-x86_64/com_test
## You may have to change com_test to something else
## everywhere it appears in this file
< envPaths
cd ${TOP}
dbLoadDatabase "dbd/com_test.dbd"
com_test_registerRecordDeviceDriver pdbbase
# Use the following commands for TCP/IP
#drvAsynIPPortConfigure(const char *portName,
# const char *hostInfo,
# unsigned int priority,
# int noAutoConnect,
# int noProcessEos);
drvAsynIPPortConfigure("IDEC","192.168.1.5:502",0,0,1)
#modbusInterposeConfig(const char *portName,
# modbusLinkType linkType,
# int timeoutMsec,
# int writeDelayMsec)
modbusInterposeConfig("IDEC",0,5000,0)
# drvModbusAsynConfigure("portName", "tcpPortName", slaveAddress,
modbusFunction, modbusStartAddress, modbusLength, dataType, pollMsec,
"plcType")
#===========BI bits ,,READ ONLY,, Temp
is:"BInput.substitutions"===========
drvModbusAsynConfigure( "BI" , "IDEC", 1, 1, 1000, 9, 0, 100,
"IDEC_PLC_message")
#===========BO bits ,,WRITE ONLY,, Temp
is:"BOut.substitutions"===========
#drvModbusAsynConfigure( "BO" , "IDEC", 1, 5, 200, 200, 0, 100,
"IDEC_PLC_message")
cd ${TOP}/iocBoot/${IOC}
## Load record instances
#dbLoadRecords("db/xxx.db","user=swdevHost")
#dbLoadTemplate("BOut.substitutions")
dbLoadTemplate("BInput.substitutions")
#dbLoadRecords("db/com_test.db","USER=swdevHost")
#cd ${TOP}/iocBoot/${IOC}
iocInit
## Start any sequence programs
#seq sncxxx,"user=swdevHost"
#asynSetTraceIOMask("IDEC",0,4) # Enable traceIOHex
#asynSetTraceMask("IDEC",0,9) # Enable traceError and traceIODriver
asynSetTraceIOMask("BI",0,4) # Enable traceIOHex
asynSetTraceMask("BI",0,9) # Enable traceError and traceIODriver
My BInput.substitutions:
##################################### BI as bits
file "$(MODBUS)/db/bi_bit.template" { pattern
{P , R , PORT , OFFSET, ZNAM, ONAM, SCAN}
####################### 10J Amplifire Moving parts Digital Inputs
{IDEC:, TEST_IN_0, BI, 1, Low, High, "I/O Intr"}
{IDEC:, TEST_IN_1, BI, 2, Low, High, "I/O Intr"}
{IDEC:, TEST_IN_2, BI, 3, Low, High, "I/O Intr"}
{IDEC:, TEST_IN_3, BI, 4, Low, High, "I/O Intr"}
{IDEC:, TEST_IN_4, BI, 5, Low, High, "I/O Intr"}
{IDEC:, TEST_IN_5, BI, 6, Low, High, "I/O Intr"}
{IDEC:, TEST_IN_6, BI, 7, Low, High, "I/O Intr"}
{IDEC:, TEST_IN_7, BI, 8, Low, High, "I/O Intr"}
My bi_bit.template:
# bi record template for register inputs
record(bi,"$(P)$(R)") {
field(DTYP,"asynUInt32Digital")
field(INP,"@asynMask($(PORT) $(OFFSET) 0x1)")
field(SCAN,"$(SCAN)")
field(ZNAM,"$(ZNAM)")
field(ONAM,"$(ONAM)")
___________________________________
Ing. Marek Böhm, RP2 Control Engineer
Institute of Physics AS CR, v. v. i.
HiLASE Centre
Za Radnicí 828
252 41 Dolní Břežany
M: +420 606 259 414
T: +420 314 007 726
E: [email protected]
W: http://www.hilase.cz <http://www.hilase.cz/>
______________________________________________________________________
Upozorneni: Neni-li v teto zprave vyslovne uvedeno jinak, neni tato e-mailova zprava navrhem na uzavreni smlouvy ani prijetim pripadneho navrhu na uzavreni smlouvy a nezaklada predsmluvni odpovednost FZU AV CR, v. v. i.
Disclaimer: If not expressly stated otherwise, this e-mail message cannot be considered as a proposal to conclude a contract, neither the acceptance of a proposal to conclude a contract, nor does it create any pre-contractual liability on the part of FZU AV CR, v. v. i.
- RE: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays Mark Rivers
Looking at ethercat and EPICS Williams Jr., Ernest L.
Re: SAES NEXTorr NIOPS-04 Vacuum Pump Power Supply Bob Gunion
<2015>
RE: Looking at ethercat and EPICS ronaldo.mercado
<2015>
