1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problem building EPICS Base 3.14.12.5 under Fedora 22
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 14 Sep 2015 11:09:06 +0530
Hello,
When I build EPICS Base 3.14.12.5 I run into some errors. Can anyone help me with these errors :
make[3]: Entering directory '/home/epics/EPICS/base-3.14.12.5/src/excas/O.linux-x86_64'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src/excas/O.linux-x86_64'
make[2]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src/excas'
make -C ./cap5 install
make[2]: Entering directory '/home/epics/EPICS/base-3.14.12.5/src/cap5'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[3]: Entering directory '/home/epics/EPICS/base-3.14.12.5/src/cap5/O.linux-x86_64'
rm -f Cap5.c Cap5.c_new
perl  -typemap /usr/share/perl5/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
Unrecognized switch: -ypemap  (-h will show valid options).
../Makefile:59: recipe for target 'Cap5.c' failed
make[3]: *** [Cap5.c] Error 29
make[3]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src/cap5/O.linux-x86_64'
../../configure/RULES_ARCHS:64: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src/cap5'
../configure/RULES_DIRS:87: recipe for target 'cap5.install' failed
make[1]: *** [cap5.install] Error 2
make[1]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src'
configure/RULES_DIRS:87: recipe for target 'src.install' failed
make: *** [src.install] Error 2
How can I fix these errors?
Re: Problem building EPICS Base 3.14.12.5 under Fedora 22 Torsten Bögershausen
Prev: Experiment Control Scientist/Engineer position at the European XFEL Adrian Mancuso
Next: Re: Problem building EPICS Base 3.14.12.5 under Fedora 22 Torsten Bögershausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
