1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem building EPICS Base 3.14.12.5 under Fedora 22
To: ishita bhatia <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Mon, 14 Sep 2015 09:16:19 +0200
You can comment out the cap5 directory from the Makefile:
http://www.aps.anl.gov/epics/tech-talk/2015/msg00024.php
HTH
/Torsten
On 14/09/15 07:39, ishita bhatia wrote:
Hello,
When I build EPICS Base 3.14.12.5 I run into some errors. Can anyone help me
with these errors :
make[3]: Entering directory
'/home/epics/EPICS/base-3.14.12.5/src/excas/O.linux-x86_64'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory
make[2]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src/excas'
make -C ./cap5 install
make[2]: Entering directory '/home/epics/EPICS/base-3.14.12.5/src/cap5'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
     T_A=linux-x86_64 install
'/home/epics/EPICS/base-3.14.12.5/src/cap5/O.linux-x86_64'
rm -f Cap5.c Cap5.c_new
perl  -typemap /usr/share/perl5/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv
Cap5.c_new Cap5.c
Unrecognized switch: -ypemap  (-h will show valid options).
../Makefile:59: recipe for target 'Cap5.c' failed
make[3]: *** [Cap5.c] Error 29
../../configure/RULES_ARCHS:64: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src/cap5'
../configure/RULES_DIRS:87: recipe for target 'cap5.install' failed
make[1]: *** [cap5.install] Error 2
make[1]: Leaving directory '/home/epics/EPICS/base-3.14.12.5/src'
configure/RULES_DIRS:87: recipe for target 'src.install' failed
make: *** [src.install] Error 2
How can I fix these errors?
Problem building EPICS Base 3.14.12.5 under Fedora 22 ishita bhatia
Prev: Problem building EPICS Base 3.14.12.5 under Fedora 22 ishita bhatia
Next: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
